Results 1 to 12 of 12
    Nothern California
    Default 2002 rx300 add master key type 1 ecu flashing issues
    i have 2002 lexus rx300
    customer had only the valet key and wanted remote as well
    i try to flash ic900 type 1 ecu with penloader was unable to get it right
    took the immo to dk friend in town to help me out
    he made Ecu virgin with some file he had try to program key
    immolight flashing
    insert key
    immolight solid but after 20-30 second light start blinking
    i think we used the wrong file for this ECU
    my part # is 89661-48310
    Now car is not starting
    need correct virgin file tks to all
    Knowledge is the Key
    Once you make it virgin you MUST have 2 keys at least, so its possible light was solid waiting for second key.
    If the security light is still illuminated, after the 2nd key, pump the brake pedal 5 times and remove the key from the ignition and wait about 80 seconds to close the programming cycle
  3. The Following User Says Thank You to shitad For This Useful Post:
    hauwkee (13th August, 2013)
    bram380's Avatar
    Indonesia +628153111774
    Can you post dump and key?
  5. The Following User Says Thank You to bram380 For This Useful Post:
    Konstantin123 (7th July, 2018)
  6. #4
    Nothern California
    i will post ecu dump and key logic tomorrow tks bram
    my friend flash it with some toyota file 16 bit
    when i try to program key the security blink
    i insert new master key light go solid after 20 30 second light go off then start blinking again
    i have the new remote key and old valet key
    ray-ray's Avatar
    Wrong key logic 4C toyota tag.
  8. #6
    DK Veteran rashid01's Avatar
    UAE
    Default virgin dump of lexus
  9. #7
    UAE
    if u need one key then u put key in to ignation then press 5 time gas padel 6 time brake padel if u need 2 key do same if u need 3 key put frist key in to ignation waite 3 second then put second key waite 3 second put 3 key start car
  10. #8
    ray-ray's Avatar
    No I don't thinks so, that is a pedal dance to add keys. Virgin dump system is set up to program 3 keys from factory, 2 master & 1 valet. Keys don't need to be cut, just use 3 keys with 4C logic the last key will register as a valet and will close the system.
  11. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    Automat (13th August, 2013), hauwkee (13th August, 2013)
  12. #9
    Nothern California
    a Dk member read and write chip for me was not able to program key i ll try today with 3 keys
    and going to try some other virgin dump
    we put key straight to dump went to the car
    the remote key don t start and the other key valet start car cannot add other key since it s a valet key
    will try again tomorrow
    Thanks to best electrical for his help
  13. #10
    ray-ray's Avatar
    The head on the penloader removes by pulling on it, use the one with cable and try your pomona clip 5250. Clean off the chip and make sure you see the flashing lights and the charge noise. That's the sign that your file was writen and compare correctly.
  14. #11
    Nothern California
    Quote Originally Posted by ray-ray View Post
    i will try in Am day 3 for lexus i feel so useless
  15. #12
    Nothern California
    problem solve reflash after 3 Raflash thanks to Best Electrical give me some of his time
    we reflash it and i add key manually the the remote key was a 4d error from supplier
    All good
    Thanks to all BRAM RAY RASHID GWEE Shitad and the one i forget sorry
  16. The Following 2 Users Say Thank You to hauwkee For This Useful Post:
    Automat (16th August, 2013), gwee (16th August, 2013)
