Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
    Default how do i put my lataitude and longitude in like
    how do i put my lataitude and longitude in like... i am using vu solo box live in leamington spa thank you all lee
    Gods Country - Liverpool
    Do a google search... It will tell you..... There is also a handy thing on UKCVs website - (i seem to recall)
    With either of them you put your postcode in and it will give you it.
    Lat - Long Finder: This page helps you find Latitude and Longitude
    Hope I have done the link right.
  3. The Following User Says Thank You to flyingpig For This Useful Post:
    youngie1 (14th August, 2013)
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Ive always used this put your full address in including house number, Andy. Satellite Finder / Dish Alignment Calculator with Google Maps | DishPointer.com
  5. The Following User Says Thank You to andy91 For This Useful Post:
  6. #4
    Latitude: 52.2666?
    Longitude: -1.5330? how do i enter it the box cheers lee
    Nov 2008
    copy and paste from a solo2 tutorial below
    Setup Motorised Dish using USALS
    First get your longitude & latitude info from _http://www.satsig.net/maps/lat-long-finder.htm
    Enter your post code into satsig.net and you'll get the correct LON & LAT info for your location.
    Example if I enter the following UK postal code: SE1 6JZ into _http://www.satsig.net/maps/lat-long-finder.htm
    I get the following LON & LAT:
    Longitude: -0.1042?
    WEST
    Latitude: 51.4979?
    NORTH
    If your longitude is a negative number i.e. it has a "-" sign before the number then you have to subtract that number from 360.
    360 - 0.104 = 359.896
    So you'd enter 359.896 in your Longitude Settings.
    Press Menu
    Select Setup Press OK
    Select Service searching Press OK
    Select Tuner configuration Press OK
    Select Tuner A Press OK
    Configure Tuner for Motorised Dish using USALS.
    Use the < > buttons on remote to select Simple.
    Use the down button to select mode and use the < > buttons to set to Positioner.
    Configuration Mode: Simple
    Mode: Positioner
    Longitude: 359.896 (Make sure you enter your own Longitude settings here)
    WEST
    Latitude: 51.497 (Make sure you enter your own Latitude settings here)
    NORTH
    Press OK to save.
    Press Menu
    Select service searching Press OK
    Select Positioner Setup Press OK
    Select goto 0 Press RED Button
    Dish should now goto 1w.
    from that site the following is shown for leamington spa
    Latitude = 52.2852, Longitude = -1.5201
    Lat = 52 degrees, 17.1 minutes North
    Long = 1 degrees, 31.2 minutes West
  8. The Following User Says Thank You to ramjet For This Useful Post:
  9. #6
    Aug 2010
    East Midlands
    Try 052.266 and 001.533
  10. The Following User Says Thank You to andy91 For This Useful Post:
  11. #7
    Nov 2008
    Quote Originally Posted by andy91 View Post
    dont you mean 358.477 for the longitude ?
    and 052.266 N for the latitude ?
  12. The Following User Says Thank You to ramjet For This Useful Post:
  13. #8
    what is the best sat to do first so they should all full in line cheers lee
  14. #9
    Nov 2008
    Quote Originally Posted by youngie1 View Post
    if your dish and motor are all correctly installed then it doesnt matter which you use, although you are best to start with 1 west which is due south of you
    if you install an up to date E2 list like the catseye one you wont have to scan anything in
    check the VU forum here for more details on your solo
  15. The Following User Says Thank You to ramjet For This Useful Post:
  16. #10
    my dish just keeps turning and not stopping was working on 28 but not anymore doing my head in now cheers mate lee
  17. #11
    ok mate i am stuck i am using a skybox f3 now as the vu solo is to hard for me..... local longitude 000.00E local latitude 00.0N what numbers do i enter in here mate cheers lee
  18. #12
    maca's Avatar
    Feb 2009
    liverpool
  19. The Following User Says Thank You to maca For This Useful Post:
    youngie1 (17th August, 2013)
  20. #13
    I KNOW THAT MATE THANK YOU I JUST DONT NO HOW TO ENTER THEM INTO MY F3 SKYBOX Latitude: 52.2666?
    Longitude: -1.5330?
  21. #14
    maca's Avatar
    Feb 2009
    liverpool
    no need to shout .
  22. #15
    Sep 2008
    i would be shouting if i had a sh1tebox also
