Results 1 to 15 of 25
    mikemike's Avatar
    H
    Default kia xcd-220rds code
    Hi!Please code from dump.
    Thanks in advance!
    mikemike's Avatar
    H
    Someone.... possible with martech???
    Thanks!
    Faraday's Avatar
    May 2012
    The dark side of the moon
    code is diode matrix, you need to remove diodes near the MCU.
  4. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    mikemike (16th August, 2013), skalpel (24th December, 2022)
    mikemike's Avatar
    H
    Quote Originally Posted by Faraday View Post
    Are you sure? Can try tonight.
    Thanks!
    Faraday's Avatar
    May 2012
    post photo from top PCB
    mikemike's Avatar
    H
    unfortunately only i can tonight
    Faraday's Avatar
    May 2012
    if there is diode matrix on left side from crystal in the bottom of MCU them you need to remove diodes and radio will start without code
  9. The Following 7 Users Say Thank You to Faraday For This Useful Post:
    arık (16th August, 2013), cscsaba (17th January, 2015), Mezz_cro (6th March, 2017), mikemike (16th August, 2013), sgm777 (16th August, 2013), skens (17th August, 2013), smoggy (6th March, 2017)
  10. #8
    mikemike's Avatar
    H
    Very thanks,works!
  11. #9
    Hungary
    Can you post a picture?
    Kari
  12. #10
    ahmetusta61's Avatar
    Jan 2012
    E.U
    code try 4x1x
    i have martech box3
    <<<<----- THANKS BUTTON
  13. #11
    shooting's Avatar
    WALES
    Quote Originally Posted by ahmetusta61 View Post
    code try 4316
    Already solved .. read post #8
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  14. The Following User Says Thank You to shooting For This Useful Post:
    ahmetusta61 (6th March, 2017)
  15. #12
    Hungary
  16. #13
    May 2017
    Hello, Can you help me ? I removed four diodes like on the picture but radio still want code what I have to do more ? My english in not perfect.
    Thank's
  17. #14
    Cymru
    Did you remove all the diodes?
    Did you make sure their are no solder bridges across the gaps?
    Did you try it back in the car?
  18. #15
    May 2017
    I removed four diodes see on the pictures (is no my foto only for example). Have to remove all diodes around the chip ? Yes I tried in car still want code. I saw nothing across the gap.
    Here is pictures whitch diode I removed
    https://ibb.co/bMEeOF
    Thank you very much
