Results 1 to 15 of 19
    DK Veteran gtmech's Avatar
    Hell
    Default Peugeot 307 wont run properly, anyone experienced this problem?
    Working on a 2006 Peugeot 307, car runs like complete crap basically. If you start up the car and let it idle its ok but as soon as you try to take off it turns bad. Just lightly touching the accelerator pedal = the car not accepting the throttle at all and car can hardly move, it wont rev up properly, it just stutters viciously on the throttle, you simply cant drive it at all. Then if you take your foot of the accelerator the car wants to just take off by itself sometimes. If you try to drive the car its just hopeless but if the car just sits there in neutral you wouldnt think there is anything wrong with it. Anyway this problem occurs in reverse and drive. Done full diagnostics check, no faults in any of the ECU at all, have tried new coil pack, no success, have tried another ecu, no success. This job is becoming a nightmare, has anyone experienced this problem before and can maybe shed some light on it? God I hate Peugeots, worst car ever made in the entire world, quality doesnt get any worse then these cars thats for sure
    Sep 2008
    checked good supply of petrol,if not could splutter when forcing the revs.
    Hell
    Quote Originally Posted by cactikid View Post
    thanks for your reply buddy, yeh checked that, fuel supply is good, fuel pressure is good, no faults found anywhere. It feels like an electrical problem but have no idea where to start looking for the problem. Anyone think a faulty BSI could cause this problem? Ok maybe not, I dont know, im running out of ideas to try
    Mar 2009
    Have you looked at live data values. What readings are you getting for throttle position and engine load when the fault occurs?
    Meat-Head's Avatar
    agree with above post.
    it's frogench so worth trying crank sensor, ther ?12+VAT or stupidly cheap from the *HOT* bird from the parts place, genuine one.
    Can you get a emmisions reading?
    Is it pheasable the muffler is collaposing and blocking up exhaust?
    Can you disable the ABS/ T/C?
    Is there a story with this one?
    are the sparkplugs correct
    Think was a ford, but check tempsensor wiring not touching HT leads
    Good one meat. Was thinking that myself. Also maybe silly but worth checking air filter and associated pipework. I had a Fiat with a big leave stuck in the tube leading to the airbox. Just past the maf sensor. And it done what your describing.. Over looked it a good few times before I found it. Lying flat in the tube until more air sucked in them it acted like a flap. Easily overlooked.. This was diesel by the way and it made a great smoke screen before dying.
    Sent from my GT-I9100 using Tapatalk 2
    Meat-Head's Avatar
    NOW THERES A GOOD POINT, BUT I DOUBT IT BEING PETROL, sorry caps lock been shouting at ebay agin.
    inlet manifolf, vacum operated flap for extra suck for egr valve?
    is the egr valve listening to Bob Marley and jambing?
    Feb 2013
    hi!
    the problem may be in the air intake butterfly
    see if it is electronic and diagnosis (actuators) to see if they work
    sorry for my English
    https://t.me/pump_upp
    i have this problem befor, it was faulty fuel pressure sensor, diagnostic say no faults in ecu, i replace the sensor and problem solved.
    hop that help
    Meat-Head's Avatar
    fpr on a pug petrol? only ever seen 2001 reno petrol with one
    Feb 2013
    South Africa
    Unplug and then remove front o2 sensor - this will give you a quick idea if the catalytic coverter is blocked. also check temperature of coolant with diagnostic tool.
    Hell
    thanks, where is the fuel pressure sensor located on the 307?
    Quote Originally Posted by bnad3m View Post
    hop that help
  13. #13
    i send you PM
    hop that help
  14. #14
    Meat-Head's Avatar
    i send you PM
    hop that help
    WHY DO THAT? If your going to dend PM with info, why advertise the fact?
  15. #15
    Just been reading a known fix for the 307. Spluttering stalling hesitation when accelerating. These lot seem to reckon the harness for engine management is known to give poor connection due to vibration over the years. Check multi plug wiring to intake air temperature sensor and map sensor. Apparently these vibrate and slacken providing a crap connection. Also a sensor on accelerator pedal relaying info to the engine ecu then to the throttle housing. .I'd be checking wiring around all this lot mate
