Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    blocked exhaust ? or ****ked cat
  2. #17
    racin-snake's Avatar
    Jun 2009
    engine code and so on might get some info to get some sorta real attempt at fixing this
    some engines and systems cause different faults and symptoms
    also what ya reading DTC'S with ?
    and whats throttle position sensor and TBH saying in live data ?
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  3. #18
    https://t.me/pump_upp
    hi meat-head
    i'm thinking that the car is diesel, he ask me in pm the sensor where is located, i reply him with picture, thats all ! i have this problem with petrol befor it was 2 coils defective
  4. #19
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    Post 5
    Can you get a emmisions reading?
    Is it pheasable the muffler is collaposing and blocking up exhaust?
    Quote Originally Posted by bnad3m View Post
    hi meat-head
    whatever, just seems daft PM information which could be used to help other members.
    During the daytime i pose as a leecher, just leeching information off unlocked INFERIOR forums (boss won't let me log onto DK anymore, spend tooo long on here)
    Helps the world go round.
    ON TOPIC:-
    Yeah multiplugs, SAME shit plugs on temp sender, as Vectra C and something else.
    The other month had THREE cars in a week, same shit plug, ford ignition coil.
    Right, bend doon, to the temp sensor, unplufg off sensor, flip off the 'end cap'
    you will then see two 'tongues' get a sawn off paper clip, use bench grinder to make it into a 'screwdriver' then CAREFULLY pry up the tongues, and pull on the wire
    When the terminal comes out, (have to be vague) you will see a hole been pressed in the terminal.
    Get your favorite drawing pin and press it back in so the inner flap grips the pin
    resaamble send on way
