that's good skydive80 I could not help but notice I see from your photos you posted the cobra-extensions-usb folder was inn the Extensions folder I hope you have removed it![]()
hi ramhir
I have had no problems with this issue could you please pm me the 4 crash logs I will look into it thanks.
Lol yeah I removed it, that's where I was going wrong the first time :-)
No the quick button plugin still installed. It kind of just worked, but now It crashes everytime I go into setup. Will try your suggestion and remove the quick button plugin.
I wouldn't try and remove it then, my problems started after I uninstall the quick button plugin,it might be best to keep it on there if you use it.
Hi ramhir
copy and paste the crash logs on here so I can look at them then I will know whats going wrong.
@ramhir if I was you I would delete everything from the USB drive download my new image with the update files on it and transport all new files back on to the USB drive that should do the trick.![]()
Hi cobra1423, Not ignoring your earlier post regarding crash logs. I am new to this, so have no idea where the crash logs are saved. Will try your suggestion of updating the USB drive with your latest image.
Ramhir- I had the same problem but it corrected itself when I reflashed the image.
Try downloading it again and starting from scratch as there are a lot of fixes in the new files.
No problem crash log files will be found on your hard drive they will say crash on them with date and time. anyway I hope you get it sorted out soon with what I told you to do.
Just to let you guys know the mediaportal plugin when you start it up go into settings by pressing menu go down to where it says x x x twice turn them from no to yes then go down and turn all the no to yes for p**n then click ok when your back at main menu you will see all the p**n icons click on one it will ask for password witch is 0000 and bingo more p**n than anyone could ask for![]()
Can anyone share what addons are working on xbmc, I have had no luck with ice films or sports devil.
All the others addons that were preloaded seem to work fine.
You'll go blind Cobra!![]()
Still no joy with the system setup menu. Tried both mastic_man and cobra1423's suggestions. Cobra, I have PM'ed you the crash log, hope you will be able to provide a solution to this.
Overall, the image works well and a big improvement over my last image.
