Your file is 100% not sure about writing back with fgtech but read is good .....
Thanks kev
Thanks kev
Novik_UA (22nd August, 2013)
Is the read original ? Can't find ori file for compare.
You may need to read in the boot-mode or BDM?
Done with BDM100.
What idiot put ECU in such idiot place
bimmer36 (14th June, 2018)
what you whant to do with file tune fapoff?
Just tuned, car was without DPF.
I post ori MPC read with BDM just for OBD write trouble case.
bdm automatically find that your ecu is mjd marelli, or you select manually?
Because file looks like mjd, but no checksum.
Yes, BDM find automatic family. And correct checksumm only in flash, but not eeprom or MPC.
Looks like MPC don't need checksumm.
Here log from connection with marelli.
Ver. 3.1.0.1255 Dongle ID: 192 Date: 24/08/2013 11:00:57
Firmware Revision V.01 SN: 0258
Mpc5xx family x00020020
PartNum: Mpc563/4 x00000036
EPEE Status: 0
EPEE Status: 1
Flash EEprom identified: M58BW016xB
Family identified: MARELLI Fiat/Opel 1.3 MJ+
+12Vcc On
Ready...
Galletto reads and writes with no problems through the OBD.read.jpgЗапись.jpg
I ask about write with FGTECH OBD in #1 post, but nobody confirm it safe, and with BDM it safe 100% .
this ecu i have done with v50 china clkone---worked 100%
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
Your tuned file
Thanks for help, but car already tuned with BDM100 read-write. Posted ori just in case if someone get error on writing to restore full memory.
