so swop file mean reverse 2 couple of numbers...
ok
but...why this? and what do this?
ok i saw now what mean swap file and different ways...but....
why i have to make a swap?
why eeprom don't have to be programmed exactly in the same way as it was read?
When a file is swap the transponder entered data are quite different.
Example
OK = 00 11 22 33 44 55 66 77 88 99 AA BB CC DD EE FF
SWAP = 11 00 33 22 55 44 77 66 99 88 BB AA DD CC FF EE
ok thank you
but... why file is swap? this is my question and why eeprom read data well anyway?
i no understand the sense of swaping...sorry....![]()
i saw on google i saw but i didn't understand well
maybe i'm too stupid to understand
i would know why swap, why on immo eeprom and why my file didn't work, just to solve in future alone
just to understand, to solve myself problems...
thank you anyway
There are two types write data (big endian and little endian). The programmer does not know which type is used. You need to know looking at the dump when you need to replace bytes.
The programmer always reads and writes in one of these systems.
UPA reads fine. GQ USB Universal Programmer doing swaps.
When there is a problem, it is good to read fault codes BSI. When there is a problem with the EEPROM (soldering) do not log in pin code, no keys, no VIN number, and so on.
i have seen a problem like this before there was a broken key taped up to theb aerial so writing new keys in didnt work because it didnt recognise the old key taped to the aerial
the only thing i can see different is the key number it should have stayed as 2 not 8
