Thread: Rar Files
    DK Veteran BRASS EAGLE's Avatar
    Central Scotland
    Default Rar Files
    i have down loaded several rar files when i try to open them iam being asked for a pass word ?? this normaly dosn't happen if the do open they are encrypted,
    can any one help me
    cheers jimmy dee
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    you will need winrar to open them, then just right click on the pile of books select extract here hey presto
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    If they are asking for a password then they have been locked. You may as well delete them unless you can find the forum or person who created them to get the unlock password.
    It is possible to crack the password with software but this can take a long time (the more characters in the password the longer it will take).
    The place where you downloaded them from sometimes subtley shows the password but not 100% of the time..
    aftermath's Avatar
    Mar 2008
    Try a winrar password cracker programme, they are free and might solve it for you. Here is one to try .
    1. Overview
    This program is intended to recover lost passwords for RAR/WinRAR archives
    of versions 2.xx and 3.xx. The program finds by the method of exhaustive
    search all possible combinations of characters ("bruteforce" method), or
    using passwords from lists ("wordlist" or "dictionary" method).
    Self-extracting archives and multivolume archives are supported. The program
    is able to save a current state (you can interrupt the program at any time,
    and restart from the same state later). Estimated time calculator allows you
    to configure the program more carefully.
    2. System requirements
    RAR Password Cracker requires Windows 9x/ME/NT4/2000/XP. There are no
    special requirements for memory capacity, but the processor performance
    should be as high as possible. Special hardware is not required.
    3. Install/Uninstall
    Install:
    Unzip the downloaded file called rpc412.zip into a temporary folder and
    run the rpc412_setup.exe file. The installer will let you choose where to
    install the program and create a program group in the Window's Start Menu.
    Uninstall:
    Unstalling of RAR Password Cracker may be carried out either by choosing
    "Add/Delete Program" in Control Panel or by choosing "Uninstall" from the
    program group.
    4. Notes on use
    1) When adding files into a project, choose the most preferable file marked
    by the program. The only exclusion from this rule is files which have a known
    fragment (for Stored files only).
    2) It is not necessary to add several files from the same archive if you
    are sure they have the same password.
    3) More than one files in a project don't slow a cracking process.
    4) Dictionary files. Here you can find some of them:
    http://www.sparkleware.com/lists.html
    security on
    http://www.accessdata.com/dictionaries.htm
    For more dictionaries use search engines, ask peoples in newsgroups,
    webforums, etc.
    5) Period of autosaving - 2 min.
    6) Don't worry about system resources - the program uses only free
    processor time and doesn't slow other applications.
    Central Scotland
    Thank you to all who has helped with there kind replies JIMMY DEE
    May 2009
    also a good idea to google the filename and the word password e.g "file.rar password", works for me as long as they are a popular download
