#include <stdio.h>
#include <stdlib.h>
#include <ctype.h>
#include <string.h>
#include <time.h>
#include <math.h>
char *latitude;
char *longtitude;
int x=0;
FILE *dataout_xml;
float lat, longt;
int xml_create()
dataout_xml = fopen("./gps_pos.kml", "w+");
fprintf (dataout_xml, "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n");
fprintf (dataout_xml, "<kml xmlns=\"http://www.opengis.net/kml/2.2\" xmlns:gx=\"http://www.google.com/kml/ext/2.2\" xmlns:kml=\"http://www.opengis.net/kml/2.2\" xmlns:atom=\"http://www.w3.org/2005/Atom\">\n");
fprintf (dataout_xml, "<Document>\n");
fprintf (dataout_xml, " <name>");
fprintf (dataout_xml, "Gps position");
fprintf (dataout_xml, "</name>\n");
// definitions for little black circle
fprintf (dataout_xml, " <Style id=\"sh_placemark_circle_highlight\">\n");
fprintf (dataout_xml, " <IconStyle>\n");
fprintf (dataout_xml, " <scale>1.2</scale>\n");
fprintf (dataout_xml, " <Icon>\n");
fprintf (dataout_xml, " <href>http://maps.google.com/mapfiles/kml/shapes/placemark_circle_highlight.png</href>\n");
fprintf (dataout_xml, " </Icon>\n");
fprintf (dataout_xml, " </IconStyle>\n");
fprintf (dataout_xml, " <ListStyle>\n");
fprintf (dataout_xml, " </ListStyle>\n");
fprintf (dataout_xml, " </Style>\n");
fprintf (dataout_xml, " <Style id=\"sn_placemark_circle\">\n");
fprintf (dataout_xml, " <href>http://maps.google.com/mapfiles/kml/shapes/placemark_circle.png</href>\n");
fprintf (dataout_xml, " <StyleMap id=\"msn_placemark_circle\">\n");
fprintf (dataout_xml, " <Pair>\n");
fprintf (dataout_xml, " <key>normal</key>\n");
fprintf (dataout_xml, " <styleUrl>#sn_placemark_circle</styleUrl>\n");
fprintf (dataout_xml, " </Pair>\n");
fprintf (dataout_xml, " <key>highlight</key>\n");
fprintf (dataout_xml, " <styleUrl>#sh_placemark_circle_highlight</styleUrl>\n");
fprintf (dataout_xml, " </StyleMap>\n");
fclose (dataout_xml);
return(0);
int place_to_xml()
dataout_xml = fopen("./gps_pos.kml", "a");
fprintf (dataout_xml, " <Placemark>\n");
fprintf (dataout_xml, "Pos");
fprintf (dataout_xml, " <styleUrl>#msn_placemark_circle</styleUrl>\n");
fprintf (dataout_xml, " <Point>\n");
fprintf (dataout_xml, " <LineString>\n");
fprintf (dataout_xml, " <tessellate>1</tessellate>\n");
fprintf (dataout_xml, " </LineString>\n");
fprintf (dataout_xml, " <coordinates>");
fprintf (dataout_xml, "%s,%s", longtitude, latitude);
fprintf (dataout_xml, ",0</coordinates>\n");
fprintf (dataout_xml, " </Point>\n");
fprintf (dataout_xml, " </Placemark>\n");
fprintf (dataout_xml, "</Document>\n");
fprintf (dataout_xml, "</kml>");
return(0);
static void callback()
int y, z;
FILE *input;
char fromrf[200], nmea_bits[40], minutes[20], latit[15], longti[15];
float min2deg, deg;
float latmin, longtmin;
input = fopen("/dev/rfcomm4", "r");
if (input == NULL)
printf ("\nNo GPS\n");
return;
while ((strcmp(nmea_bits, "$GPGGA"))!= 0)
fgets(fromrf, 100, input);
for (x = 0; x <= 6; x++) nmea_bits[x] = fromrf[x];
nmea_bits[6] = '\0';
// At this point I have a valid GPGGA string in fromrf
// Check the GPS has a fix
y=0;
for (x=0;x<=5;x++)
while (fromrf[y++] != ',');
// y has the position of the "fix or no fix" digit
if (fromrf[y] != '1')
printf ("\n No fix %c\n", fromrf[y]);
return;
// Got here, have a fix
// I need to extract lat and long, here is a valid line
// $GPGGA,141733.000,3742.434306,N,02403.104390,E,1,4 ,5.25,53.819,M,35.179,M,,*68
// $GPGGA,064733.327,3742.4148,N,02403.0913,E,1,03,12 .8,0.0,M,35.2,M,0.0,0000*48
// Time: 141733.000, 14:17:33, 1000ths of seconds, not needed
// 3742.434306,N, 37 degrees, 42.434306 minutes, North. 11 digits needed and the N (it maybe S sometimes)
// 02403.104390,E, 24 degrees, 03.104390 minutes East. 12 digits needed and the E (it may be W sometimes)
// 1 have GPS fix, anything else means no fix
// The rest are of no interest, maybe checksum at the end if we have problems
//printf ("%s", fromrf); // print all of the string
y=0;
for (x=0;x<=2;x++)
y--;
x=0;
z=y;
while (fromrf[--z] != ',');
// y is the comma at the end of the latitude
// z is the comma at the beginning of latitude
if (fromrf[y+1] != 'N') nmea_bits[x++] = '-';
z++;
//These two for the whole degrees
nmea_bits[x++] = fromrf[z++];
nmea_bits[x++] = '\0';
// z points at the MS minutes digit
x=0;
if (nmea_bits[0] == '-') minutes[x++] = '-'; // if degrees are negative make minutes negative
while (z++ < y)
minutes[x++] = fromrf[z-1];
minutes[x++] = '\0';
// We have number of whole degrees in "nmea_bits", minutes in "minutes"
// "minutes[]" and "nmea_bits[]" needs converting to floats
// divide minutes by 60, add to nmea_bits
// and converting to a string stored in latit[]
// that will give us the latitude in degrees and decimal degrees
// Get previous lat and long for path and distance
// As floats here
min2deg = atof(minutes);
min2deg = min2deg / 60;
deg = atof(nmea_bits);
lat = deg + min2deg;
sprintf (latit, "%f", lat);
latitude = latit;
// latitude as degrees now stored in latit[] and displayed in latitude box
// x is not needed, y and z are the same and are the comma before the N
// nmea_bits[] is not needed, minutes[] is not needed
y=y+3;
// We should now be at the first digit of the longtitude with y
x=0;
z=y; // and z
// need to find sign (East or West)
// y is now the sign, East or West
if (fromrf[y] != 'E') nmea_bits[x++] = '-';
// sign sorted
// whole longtitude degrees into nmea_bits
nmea_bits[x]= '\0';
// whole degrees sorted
x=0;
while (z++ < y)
longt = atof(nmea_bits);
longt = longt + min2deg;
sprintf (longti, "%f", longt);
longtitude = longti;
// Latitude, Longitude, N, S E and W now sorted
place_to_xml();
int main( int argc,
char *argv[] )
latitude = "No data";
longtitude = "No data";
printf ("%s, %s\n", latitude, longtitude);
while (1)
xml_create();
callback();
printf ("%f, %f\n", lat, longt);
sleep(2);
return 0;
