Results 1 to 3 of 3
    May 2013
    Default Help about Multi-bouquet !!!
    hi ! When i put SKY UK bouquet channel in my dreambox 800 HD i lose the other bouquets ! I use dreamboxEdit ,and i have activate MULTI BOUQUET in setup menu of the box . And when i try to inject the others bouquets i lose the sky uk bouquet channel !!! HELP PLEASE
    May 2013
    No one can help me ???
    happy_highlander's Avatar
    Aug 2010
    You will need to add all the services from the 28.2 sat into you current multi sat list using dbe then import all your user bouquets from 28.2 list that you have open on dbe into the multi sat list you have in another dbe window. If you don't add the services first you won't be able to import the user bouquets but before you do all that you will have to make sure the satellite.xml you are using for your multi sat list contains 28.2 or none of the above will work.......Simples
    Or you could do it the real really easy way and make sure that the option to remove unused bouquets isn't ticked
