Results 1 to 8 of 8
    Top Poster sandu007s's Avatar
    Aug 2011
    Default pease help with tuning for vw passat 2005 ed15p-19
    I have galletto 2 FGTECH the china clone .. I read the flash by obd but I am fraid to write the file with egr off because I heard is a problem with checksum when write the file.. Can anyone help me?
    This file is 100% original.
    checksum is 100% ok.
    Br.
    Aug 2011
    but when change the file with egr off or other changes I need to make checksum? THANKS
    Normaly any editing software can do automaticaly checksum en edc15P.
    Ecm, winols, etc.
  5. The Following User Says Thank You to gezame For This Useful Post:
    sandu007s (25th August, 2013)
    Aug 2011
    I will try to write the file that I changed with volta through obd with the clone of galletto2 and see what happens.. Thank you very much
    Aug 2011
    volta not correct the cecksum-you will have a bloked ecu
    Dec 2010
    Write me on email what do you whant to do with file i can help with tune and egroff - tsracing.bel @ gmail . com
    Dec 2010
    your tuned file
