Results 1 to 15 of 15
    Senior Member Novik_UA's Avatar
    Jun 2010
    Default Opel Astra H 1.3CDTI 90Hp HW03F 32709A143 2006 read by FGTECH
    Hi.
    Today read Opel Astra H 1.3CDTI 90Hp with FGTECH Can mode.
    WinOls did't find marelli checksumm, maybe is bad read ( but really looks OK for me but ...)
    Please check ori file, is readed good, and is safe to make mod on it and write with FGTECH with checksumm on writing.
    kevfield's Avatar
    Aug 2009
    uk
    Your file is 100% not sure about writing back with fgtech but read is good .....
    Thanks kev
  3. The Following User Says Thank You to kevfield For This Useful Post:
    Novik_UA (22nd August, 2013)
    Jun 2010
    Is the read original ? Can't find ori file for compare.
    Apr 2013
    You may need to read in the boot-mode or BDM?
  6. #5
    Jun 2010
    Done with BDM100.
    What idiot put ECU in such idiot place
  7. The Following User Says Thank You to Novik_UA For This Useful Post:
    bimmer36 (14th June, 2018)
  8. #6
    Dec 2010
    what you whant to do with file tune fapoff?
  9. #7
    Jun 2010
    Just tuned, car was without DPF.
    I post ori MPC read with BDM just for OBD write trouble case.
  10. #8
    Dec 2010
    bdm automatically find that your ecu is mjd marelli, or you select manually?
    Because file looks like mjd, but no checksum.
  11. #9
    Jun 2010
    Yes, BDM find automatic family. And correct checksumm only in flash, but not eeprom or MPC.
    Looks like MPC don't need checksumm.
    Here log from connection with marelli.
    Ver. 3.1.0.1255 Dongle ID: 192 Date: 24/08/2013 11:00:57
    Firmware Revision V.01 SN: 0258
    Mpc5xx family x00020020
    PartNum: Mpc563/4 x00000036
    EPEE Status: 0
    EPEE Status: 1
    Flash EEprom identified: M58BW016xB
    Family identified: MARELLI Fiat/Opel 1.3 MJ+
    +12Vcc On
    Ready...
  12. #10
    Apr 2010
    Russia
    Galletto reads and writes with no problems through the OBD.read.jpgЗапись.jpg
  13. #11
    Jun 2010
    I ask about write with FGTECH OBD in #1 post, but nobody confirm it safe, and with BDM it safe 100% .
  14. #12
    Nov 2009
    UK
    this ecu i have done with v50 china clkone---worked 100%
    MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
  15. #13
    Apr 2013
    Quote Originally Posted by serguei View Post
    I do not see anything on your screen shots. Share them with good resolution.
  16. #14
    Dec 2010
    Your tuned file
  17. #15
    Jun 2010
    Thanks for help, but car already tuned with BDM100 read-write. Posted ori just in case if someone get error on writing to restore full memory.
