Page 4 of 4 FirstFirst 1234
Results 46 to 60 of 60
  1. #46
    Nothern California
    got a window xp laptop
    and pocket pc
    i m trying installing get error missing
    install the sync device
    said i have missing .net compact framework 2
    the crash installation can someone give step to install
    i try download framework file not sure how to install it
    Knowledge is the Key
  2. #47
    Quote Originally Posted by hauwkee View Post
    and pocket pc
    I think I just went to programfiles where it puts all the files then copy the folder over to sd card -> pocketpc then made a shortcut to the executable and ran it that way, as I didn't have activesync all setup etc
  3. The Following User Says Thank You to paul_12345 For This Useful Post:
    hauwkee (9th July, 2014)
  4. #48
    Nothern California
    made a shortcut to the executable how you do that paul
    i try to put file dont let me pocket pc .exe did not work
  5. #49
    just let the install complete but cancel when ask you if your device is connected.
    then go to program files, and copy the "Pocket InstaCode" folder to sd card.
    put sd card into pocketpc and open file manager the go to the sd card, Pocket InstaCode, the try running the pic.exe direct.
  6. The Following User Says Thank You to paul_12345 For This Useful Post:
  7. #50
    Nothern California
    Thanks Paul get it running
    my device id is fe9fc815
  8. #51
    I make it to install in pocket PC need company info and reg 1 2 3 4
    i got old keygen from insta 2006 might work trying no success
    see my first post for name/serial etc
  9. The Following User Says Thank You to paul_12345 For This Useful Post:
  10. #52
    Nothern California
    i saw it correct post but u so good u already answer me device id fe9fc815
  11. #53
    code is 277d189f
  12. The Following User Says Thank You to paul_12345 For This Useful Post:
    hauwkee (10th July, 2014)
  13. #54
    Hi Paul
    Can you please send activation code for Device id 2b37f981
    Many thanks in advance.
  14. #55
    Quote Originally Posted by u.s View Post
    Hi Paul
    code is 8ac2d550
  15. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    kevfield (29th May, 2016), u.s (28th March, 2016)
  16. #56
    kevfield's Avatar
    uk
    Hi Paul can you activate this please.
    b2771475
    Thanks Kev
  17. #57
    Quote Originally Posted by kevfield View Post
    b2771475
    Thanks Kev
    your code is 8a06c207
  18. The Following User Says Thank You to paul_12345 For This Useful Post:
    kevfield (6th June, 2016)
  19. #58
    Dec 2016
    Untitled.jpghi guys, im need help for registration.. can help me anyone ?
  20. #59
    Dec 2012
    EU
    Was this not band?
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  21. #60
    Dufner
    Johnner's Avatar
    Éire
    Yes it was,as it was going to get the forum into hot water...so I'm closing this thread....Sorry !!
  22. The Following User Says Thank You to Johnner For This Useful Post:
    gttuning (19th December, 2016)
