Results 1 to 8 of 8
Thread: flashing xbox
    Jul 2013
    Default flashing xbox
    hi planning gon getting my xbox 360 flashed, i have found someone to do it, what do i need to make sure i do in order NOT to get banned, ie what kind of games, use abgx etc etc? as i had one a few years ago and it got banned after 2 months, so i want to do it this time but do everything right and safe.. help and guides will help thanks edit : what kind of programmes and burners do i need? i seen something called an i has?
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Run each game image through ABGX. USe imagburn with burner max fw or payload on compatable drive with verb discs and should be fine provided burn quality and drive laser is fine
    Jul 2013
    Quote Originally Posted by cunny View Post
    how should I burn, I have a liteon burner model number : eZAU120 is that fine? and also what are some tip snot to get banned etc thanks my fellow man utd fan!haa
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Just as i posted above.
    Run each game through ABGX before burning.
    Burning with compatable burner with burner max
    Use verbs
    Dont play before release dates
    north west
    also you could flash with latest lt firmware i think lt 3.0 was latest but not been online to check lately, once flashed copied games are undetectable on live.
    keep a spare drive handy though (same make and model) and use it just to do dash updates then plug back in your flashed drive.
    happy days.
    Jul 2013
    hi thanks for reply whats burner max? and how do I use it don't you use img burn for burning, confused, thanks matey
    Use verbs
    Jul 2013
    hi mate where do I get a drive from are they easy to put in and out is it the hard drive? or something else? cheers
    Quote Originally Posted by veccytester View Post
    happy days.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by tayyab95 View Post
    Burner Max Payload is a prog that allows burners to burn to the end of the disc safely. It may have been intergrated into ImgBurn, you'd have to google it as i aint spoon feeding everything.
    You can purchase spare/replacement drives. You would still need to flash your drive information over to it, be it in a stock fw or lt fw. If you cant do it, then sometimes the drive supllier can
