Both versions are already unlocked, so no need to use the keygen
IMG version:
http://www.mediafire.com/download.php?dunimdt0jny
http://www.mediafire.com/download.php?movlyxmgegw
http://www.mediafire.com/download.php?tjmeiwmjz50
http://www.mediafire.com/download.php?my5zr5mhmj5
http://www.mediafire.com/download.php?jmq5ezmeunw
http://www.mediafire.com/download.php?whlyvwmdmmi
http://www.mediafire.com/download.php?jm1dtm2dykd
http://www.mediafire.com/download.php?jmm0zzamcg1
http://www.mediafire.com/download.php?ogtdjw35oww
http://www.mediafire.com/download.php?v1nmom4zzzu
http://www.mediafire.com/download.php?zylmgymnmmm
http://www.mediafire.com/download.php?b1ihkwdzttz
http://www.mediafire.com/download.php?ob2jjrwn0mr
http://www.mediafire.com/download.php?jjhmj05woyh
Mapsource Version:
http://www.mediafire.com/download.php?qmiggumm0yz
http://www.mediafire.com/download.php?0zayenfrymm
http://www.mediafire.com/download.php?z2zhkomd2en
http://www.mediafire.com/download.php?mtq3nwdrem1
http://www.mediafire.com/download.php?fwmohbkmzbj
http://www.mediafire.com/download.php?y2j1iteomjj
http://www.mediafire.com/download.php?znznegthtji
http://www.mediafire.com/download.php?jhjizn5mzud
http://www.mediafire.com/download.php?zuozimn3cmo
http://www.mediafire.com/download.php?2kh3itzzk4y
http://www.mediafire.com/download.php?jzlyynbzni2
http://www.mediafire.com/download.php?2m23ylm4zi2
http://www.mediafire.com/download.php?dwnmoxewzln
http://www.mediafire.com/download.php?mtjewy1eemm
http://www.mediafire.com/download.php?wduk4n2ztmi
How to install Mapsource version:
1) remove any other version of Garmin City Navigator Europe 2010.10 for Mapsource
2) install Mapsource v6.15.4
3) Unrar all the files in a dir
4) Run install.bat that you find in the dir choosen early
5) Run Mapsource and if ask for a serial number, just use one for the MapID 449
If you want to uninstall Garmin City Navigator Europe 2010.10 , simply run Uninstall.bat
mirror:
1. Unpack password for all rar files is : tom1807
2. Download the jetmouse key generator.
3. Get your Garmin GPS 10 digit unit ID number by turning on your GPS and going to system settings then "About" and you will see the ID number. Alternative way is to plug your GPS into your computer and go into the Garmin folder and you will see a file called GarminDevice.xml, open it and you will see a 10 digit number right in the first few lines of code.
4. Open the jetmouse 1.5 keygen you downloaded, then copy and paste your 10 digit unit ID number into the first field. Then where it says "Select Map Product," go to "Custom Mapset" and enter "449"
5. There are two "Generate" buttons, click the bottom "Generate" button to get your map unlock code, you do not want to click the top generate button because that generates a software unlock code, which you do not need.
6. Copy (Ctrl+C) the map unlock code to your clipboard, then create a new text file on your desktop (Right click on desktop, new, text document) and paste (Ctrl+V) the code into it, now save the text file as "gmapsupp.unl" After you save it using that extension, you should not be able to open it anymore since it's no longer a text file unless you choose to associate .unl files with notepad.
7. Get a 2GB or more SD card and format it FAT or FAT32, create a folder on it called "Garmin" then copy and paste the "gmapsupp.img" file in this torrent along with the "gmapsupp.unl" you created into the Garmin folder on your SD card.
8. Insert the SD card into your Garmin GPS, and browse to your map information on your Garmin GPS and you should see the new maps selected. Tools>Settings>Map>Map Info. Make sure your old maps are de-selected, or it will show two POI's for an identical location.
DOWNLOAD:
Original Mapsource installation (run .msi file to install):
http://rapidshare.com/files/221087818/cneu_2010_10_ms.part01.rar
http://rapidshare.com/files/221096412/cneu_2010_10_ms.part02.rar
http://rapidshare.com/files/221096281/cneu_2010_10_ms.part03.rar
http://rapidshare.com/files/221107594/cneu_2010_10_ms.part04.rar
http://rapidshare.com/files/221108603/cneu_2010_10_ms.part05.rar
http://rapidshare.com/files/221118465/cneu_2010_10_ms.part06.rar
http://rapidshare.com/files/221118600/cneu_2010_10_ms.part07.rar
http://rapidshare.com/files/221130358/cneu_2010_10_ms.part08.rar
http://rapidshare.com/files/221131102/cneu_2010_10_ms.part09.rar
http://rapidshare.com/files/221144266/cneu_2010_10_ms.part10.rar
http://rapidshare.com/files/221143397/cneu_2010_10_ms.part11.rar
http://rapidshare.com/files/221160407/cneu_2010_10_ms.part12.rar
http://rapidshare.com/files/221161674/cneu_2010_10_ms.part13.rar
http://rapidshare.com/files/221179350/cneu_2010_10_ms.part14.rar
http://rapidshare.com/files/221173304/cneu_2010_10_ms.part15.rar
IMG:
http://rapidshare.com/files/221206568/cneu_2010_10_img.part01.rar
http://rapidshare.com/files/221191215/cneu_2010_10_img.part02.rar
http://rapidshare.com/files/221195007/cneu_2010_10_img.part03.rar
http://rapidshare.com/files/221209200/cneu_2010_10_img.part04.rar
http://rapidshare.com/files/221221970/cneu_2010_10_img.part05.rar
http://rapidshare.com/files/221224789/cneu_2010_10_img.part06.rar
http://rapidshare.com/files/221236978/cneu_2010_10_img.part07.rar
http://rapidshare.com/files/221251804/cneu_2010_10_img.part08.rar
http://rapidshare.com/files/221240348/cneu_2010_10_img.part09.rar
http://rapidshare.com/files/221269244/cneu_2010_10_img.part10.rar
http://rapidshare.com/files/221288045/cneu_2010_10_img.part11.rar
http://rapidshare.com/files/221288919/cneu_2010_10_img.part12.rar
http://rapidshare.com/files/221269124/cneu_2010_10_img.part13.rar
http://rapidshare.com/files/221291988/cneu_2010_10_img.part14.rar
for pc or garmin units:
3D-Buildings
http://rapidshare.com/files/221079163/cneu_2010.10_3d.part1.rar
http://rapidshare.com/files/221078623/cneu_2010.10_3d.part2.rar
http://rapidshare.com/files/221087065/cneu_2010.10_3d.part3.rar
Lane Assistant;
http://rapidshare.com/files/220882069/cneu_2010.10_jcv.rar
