Results 1 to 8 of 8
    Dec 2010
    Denmark
    Default Help me to corect the cheksum's on a file!
    Pls help me to do the checksum's on the file attached!
    Thank you in advance!
    Checksum are ok! esta todo corregido en este archivo!
    Jul 2011
    Your CHK seems to be correct.
    I will check this tomorrow again with ols ..
    Dec 2010
    Denmark
    Thank you! Can you also tell me if is a good map so I can write it on the car?
    post ori file for comparison
    Jul 2011
    Maps are not perfectly but not so Bad tuned, you can Test it ..
    Checksum are 100% Okay
  7. The Following User Says Thank You to thebigf2 For This Useful Post:
    jorjelut (28th August, 2013)
    Dec 2010
    Denmark
    This is the original!
    Is absolutly sure that I will not have problems? Thanks!
    Donw with titanium, not too bad except MAp map and drivers wish...start to increase from very low , I mean there s no need to modifiy values below 1100 rpm..
    But i dont think you llhave any problems...probably a bit smokey
  10. The Following User Says Thank You to ominimicu For This Useful Post:
    jorjelut (29th August, 2013)
