Results 1 to 8 of 8
    Argento7's Avatar
    Costa Rica
    Exclamation Hyundai Accent Odometer
    Please friends, help me with my nightmare...
    I was trying to correct mileage of this car. Accent GL 2003. Odometer value 149981.
    I found eeprom 93s56. I dont have any "market" eeprom programmer, but my homemade allways do de job correctly.
    But this time, with eeprom out of board, have a lot of trouble to read dump. Finally can but dump have no sense for me. So I put eeprom again and test in car... ERROR
    I have a good car scaner, but this car look like have problem with OBDII connector or lines... so, I disconnect battery @ 1 hour and again ERROR.
    I was reading @ 93s56, look like is not same as 93c56...
    Please, how can I fix this?
    This is my reading of dump...
    __==41 72 67 65 6E 74 6F 37==__
    fuktak's Avatar
    Sep 2010
    Bulgaria
    Your dump is corupted.Try with this one.BR
    Joseph "Proposition Joe" Stewart
  3. The Following User Says Thank You to fuktak For This Useful Post:
    Argento7 (28th August, 2013)
    Argento7's Avatar
    Costa Rica
    Quote Originally Posted by ***tak View Post
    Thanks alot friend. 11:20 p.m. here. I try it tomorrow and post if work.
    here is good dump....
  6. The Following User Says Thank You to billykillkelly For This Useful Post:
    Argento7's Avatar
    Costa Rica
    Somebody know if 93s56 can be replaced with normal 93c56?
  8. #6
    yes you can no one can not stop to you even andersonmaxi)))
  9. #7
    Argento7's Avatar
    Costa Rica
    Quote Originally Posted by billykillkelly View Post
    Sorry friend, I dont understand...
  10. #8
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    I had the same issue on this Hyundai Grx which has a eepro. 93s56 i did read 3 devices using DGP3,UPA 1.3 and CARPROG... When i read the dump shows ok but when i tried to change mile age shows error and tried to read the dump again shows nothins happen.. so what i did is replaced the dump using other eeprom Ra57 or 93c56.... i having this problem on hyundai grx and hyunda accent and hyundai h100.... i dont know where is the problem at all... anyone had the same problem and did solved?
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
