HI,
install is Tricky, and to run BDM Mode same.
ATTENTION the Chinese People has installed little Friends inside the Windows Image!! Don?t use Internet
hi guys
trying to install this tool
not playing ball
i bought it from here
New Version V53 FGTECH Galletto 3-Master EOBD2(A QUALITY) with BDM Adapters
it came with a ghost disc with aan image of xp on it
installed that to a spare partition i have on my laptop
but still wont graft :S
has any1 managed to get it grafting ?
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
HI,
Hi dave did you use the fix usb first ?? what error codes u getting or are you getting nowt ???/
Thanks kev
You must set Date 1.1.2013 and then make USB Fix
who are working with galletto 3 v53 with success? i know there's only problems....
ProTuner since 1999
I have a V53, but from a different Chinese and it works fine..
Although I had to solve many problems, installation, switch BDM / OBD / TriCore etc.
Wiring the heads etc. However, I had to kill many Trojans on the Windows installation.
Is for read only for experiments and rapid advance OBD.
Without reasonable backup mine is always too hot, but flash goes
I have other original tools .. KTAG, BDM100 V3 ,CMD OBD + BDM
is defective since the CMD USB port I needed something to read OBD ..
The idiot of CMD want over 400 euro for a repair + shipping to Switzerland
then there's the problem with the customs it.
F *** in arrogant CMD people, the Service is soo BAD !
- look at this
FGTech Galletto 2-Master - PDF Manuals for Auto-Tool-Shop.com
http://car-prog.com/g3/2_G3_v2012setup.exe i haven't v53 and dongle yet. i cant test.
WFG!!! I try soft for car-prog in my china clone, and now not work!! only ask for renewal and eobd2.exe error.....
ATENTION NO TRY WHIT CHINESE CLONE!!
Fg fix tool not work. Please If you have one fix, send me i agree you a lot.
Thanks for all
Can anyone check on his Galletto v53 if it supports the following ?
"09/12 OBD driver for Simos 10.xx VAG 1.2 TSI Read/Write, Checksum" It was added in September 2012... I don't know what's the release date for v53...
If anyone could check inside the software I would apreciate it.
Thanks!
