Results 1 to 7 of 7
    rtvservis's Avatar
    Default REIDING ECU SUZUKI VITARA EDC16C3 DDSI 1.9 PROBLEM
    2006g DDSI 1.9 DIZEL 0 281 012 569 EDC16C3
    TRAY TO READ BAY GALIETO 2 OBD AND DIRECTLY ON BANC BAY K LINE .
    NOT WORKING . ENY SOLUTION PLEAS HELP
    Spain
    Quote Originally Posted by rtvservis View Post
    Try to read with BDM , The last month , i read and write the same ecu with BDM and no problem.
  3. The Following User Says Thank You to williams12 For This Useful Post:
    rtvservis (29th August, 2013)
    soxten's Avatar
    Mar 2013
    I did one to night, used Ktag and BDM. (Mcu,flash,Eeprom)
    On the broken ecu the car don't starts when coold.
    I did read and Eeprom ST95160 and programed to a used box.
    On broken box i could not read flash, get checksum error 99% reading on Ktag.
    LaraVAG's Avatar
    Jun 2011
    When you use K-tag you must first insal original K-siut, next delete all files what you insatl, and next instal clone software. No checksum 99% Error
  6. The Following User Says Thank You to LaraVAG For This Useful Post:
    soxten (8th October, 2013)
    Nov 2012
    smartville in front of a OBDplug
    i did it obd
  8. #6
    rtvservis's Avatar
    Default i menage to read ecu bay BDM
    I HAVE VOLT AND ECUSAFE DID DEJ WORK ON THIS ECU AND WHERE IS FAP ON EXT FLAS OR INT FLASH.
    IF ENBYD CAN MAKE DPF OF WITH WORKING GOOD PLEAS HELP
  9. #7
    Aug 2012
    LATVIA
    only manuall solution
