Glitching Eurovox 2008
Results 1 to 7 of 7
    May 2008
    Im from Manchester in the United Kingdom
    Downloads
    25
    Uploads
    Default Glitching Eurovox 2008
    Hi There
    My mate has a eurovox 2008 but it glitches like mad, I have tried it at my house and at his so it has been tried on 2 different feeds and it just does the same thing, the glitching makes it unwatchable.
    I have tried several images (firmware) and there is no difference.
    Does anyone have any suggestions
    Cheers
    Fermec
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    66
    Downloads
    291
    Uploads
    112
    Are you using any splitters? At your or your mates? Try to connect the box to the main feed and see if it's any better.
    May 2008
    Downloads
    10
    Uploads
    splitters thing doesnt work.
    I tried it and its no way goin to solve this.
    its just something wrong with evox.
    I m sure DRmbox will work fine at place.
    ask him to get Drmbox and then see .
    i know its not solution, but its one option.
    if anyone has solution pls pls post
    Jun 2008
    Downloads
    22
    Uploads
    what signal levels he getting?
    anything above 80% can cause the probs youve described
    If the levels are high try an attenuator to reduce the signal and it should solve his probs
    Mar 2008
    Downloads
    57
    Uploads
    i tied all cables and splitters and in the end i added a heatsink on with superglue and heatsinkcompoudn with a very quick mix he he.
    did the trick for me...
    Apr 2008
    Downloads
    123
    Uploads
    Try a booster, e-bay will see you alright.
    Apr 2008
    Downloads
    6
    Uploads
    Press the info button twice on a channel thats breakin up..if it reads 8%..theres a fix for this...
