i have this cable and i need help for solder on carprog 4.74
ARM JTAG parallel Programmer Kabel (Wiggler-Kompatibel); P009.06 | eBay
Thank you
Thank you
hi need carprog
http://www.digital-kaos.co.uk/forums...ssword-363587/
here ya go mate its right here if you use search in top of the page don't forget to thank the authors and the contributors to that thread please
they give their help for nothing !!
http://www.digital-kaos.co.uk/forums/f171/carprog-mcu-reflash-step-step-288814/
Today is the Tomorrow you worried about yesterday ......Was it worth it ?![]()
same programmer in link as i bought works fine although the wiring on mine was inverted but that wouldn't connect to target
try again making sure you clear the flash in mcu
sepistar (11th September, 2013)
no matter what i do it give me same error:time out.this mean something goes wrong.it start programing and after exactly 2,20 sec stopped with the error i write above.i try a lot of combination,short cable-long cable,2 different pc(1 laptop,1 desktop)with or without eeprom on board,if connection from the other thread or from here,all make no differences.
br.
have sorted out!!the programing process was always interrupted due to missing gnd on mcu.after the mcu has gnd then programming was done in 5 sec.
br.
