if the ecu is me9 you can do this bdm and obd, not with old galletto.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
you see the bootmod document.
ALL TUNING.
what year focus maybe kess v2 can do depends on year
there have been cases of FGtech 2 via OBDok...Never use mpps on this ecu. Problem always is that after mod, 1 checksum block gets detelted ot tools, delete ECu iD.
Safest is BDM
Focus RS ecu is ME9.0c NOT ME9.0. Can protocol is changed on this revision and no tool can do this by OBD up to this date. Only BDM my friend, but if you use cloned FGTECH you won't get it to work in BDM. It says MCU NOT SUPPORTED ERROR. I tried with K-TAG and worked ok
If this was helpful press the "thanks" button
TUNING FILE SERVICE SINCE 2008
Kess have in obd car-list, but i do not tested.
Br.
Byetshooter does ME9c. Genuine Kess as well.
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
nick_f (16th September, 2013)
BDM read and kess v2 write. I have done with genuine tool. Or possibly get matching original file and write only?
euroscan1 (22nd September, 2013)
