Results 1 to 4 of 4
    Vilnius, Lithuania
    Default Simos 7.1A pin code
    Need some help for simos 7.1A. VW Touran
    AVDI can't read pin or other information from engine ecu. So as AVDI dump tool.
    I need to adapt new instruments cluster. Old one is lost. Key is original.
    Any ideas ?
    42352 seems to be wrong.
    Am i right about CS- 11 2F A0 F5 23 5E 01 ?
    trying to find help in AVDI forum, but still no answer
    qwertyuiop12's Avatar
    May 2013
    Pin Code: 42352 is correct 100%
    CS: 11 2F A0 F5 23 5E 01 is correct 100%
    Apr 2011
    in lebanon
    Quote Originally Posted by dodiss View Post
    Any ideas ?
    Hello.
    try this pin 28837 + 6 bytes 2F 11 F5 A0 5E 23 00.leave the ignition on 30 minute,and after try this pin and see did accept? and about lost the instruments cluster,so in this case u must adapt new key to new instruments cluster. u can't re adapt the original key to the new instruments cluster.
    Vilnius, Lithuania
    qwertyuiop12, i saw 42352 from the dump as well, leaved ignition on for whole night, but nothing. so ?ts the reason i'm confused.
    Thanks haroutioun. Will try on holidays.
