M2 PIN 8 +12V
M2 PIN 3 GND
M3 PIN 20 CAN H
M3 PIN 19 CAN L
M3 PIN 13 +12V
I include photos boot
M2 PIN 8 +12V
M2 PIN 3 GND
M3 PIN 20 CAN H
M3 PIN 19 CAN L
M3 PIN 13 +12V
thanx but it is not mine board
look at the coil and the capacitors near
are different orientation,
and i havent theses points like your picture
give me number HW control unit please
here is the ticket attached from ecu....
I'm sorry I have no solution for this.
upload picture with mcu tricore !!
Mike
EDC17C41
Bootpin and processor are on the bottom of the board!
the board will be glued, and will stich hard at bottom side?
its risc to split it?
need to hot it or some other hint ?
thx
Yes, there is a risk to kill the board. Please go to a tuner that has already done this and ask him if you can watch his work.
there is a magpro tool where it drills a hole in outer casing, in exact location,
had this same ecu the other day, was disspointed to see that you need to seperate both cases of metal to obtain boot,
i cant see that you can split without damage, i used allot of HEAT !! and could see and hear board stressing,
so i put back together to send customer to someone else to BREAK / TUNE :> ecu,
