Results 1 to 15 of 20
    fruti's Avatar
    Default Renaul Clio SAFIR 2 PROBLEM
    Hello guys!
    I just lose my temper today !
    I CUT also line 30
    I try to IMMO off on SAFIR 2. I try with 23 pin to GROUND NOT WORKING ... Car won't start!
    I try Immo DECODER .... Same shit don't work ... Car won't start.
    If i mess WITH KEY car start .... like it was not virgin.
    So is it possible i need EMULATOR ?
    Don't know what to do any more
    Please HELP
    skens's Avatar
    Zagreb,Croatia
    hi
    not by type of car!!
    The most important information that you have 27c512 or 28c512 inside
    because there is a difference if the 27c then to 23 pin mcu
    , if it is 28C to 22 pin MCU
    immo pin 30
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
    fruti's Avatar
    Bro ... it is 27c512 But don't work ....
    fruti's Avatar
    I just reading this and i see i need to put Safir2 to ADVANCED 1 or 2 mode ... i use Standard.
    If i working via 23 pin to mass .... nothing happen. I know that it must CLICK CLICK and restart fuel pump but when i do that it nothing happen. No restarting no noise.
    That why i use this Immo decoder ... i will leave that for 4 hours and lets see what will happen
    Decoding process is fully automated. On SIEMENS FENIX5 select Standard type of operation (green LED off). Other systems may require
    Advanced1 or Advanced2 mode (especially engine control systems, where
    ignition-on signal to ECU is passed via fuel pump relay coil, e.g. SAFIR2).
    Decoding in Standard mode takes about 1h 50min, in Advanced 1 ***8211; 4h, in
    Advanced 2 ***8211; more than 5h. In most cases 1h 50min is enough to make
    ECU not coded. Ignition is switched from off to on by decoding tool; red
    LED indicates ignition on. After decoding, ignition is switched off and
    green led is lit permanently.
    fruti's Avatar
    Ok ... Advanced 1 mode .... now 4 hours waiting
    Sagem SAFIR 2 IMMO off - YouTube
    May 2013
    Hello, look this tutorial password in mp,
    simply put on the photo I touch the red pine with a small screwdriver up and down.
    connected computer on the car ignition is.
    A +
  7. The Following 8 Users Say Thank You to dell66 For This Useful Post:
    airfree (28th September, 2018), amrif (17th October, 2019), anour10 (3rd January, 2019), Disconnected (18th April, 2016), egycyclops3 (11th May, 2018), Le-Mans (23rd July, 2018), r0my81 (10th August, 2015), Sady369 (30th June, 2021)
    Nov 2010
    Seafront
    Hi, i have the same problem here . The car is far away and i need a working solution.
    SAfir 2 with 55 pins
    Chip: 27c512
    I did the Renault - Tool - advanced for 4 hours
    After i checked : light goes on and after 2 seconds goes off like before
    I tried the tiny sweeper and connect the signal cable to pin 23 (and also tried pin 22) - pin 23 is ground directly (my opinion is this pin should
    be lifted up to make the tiny sweeper working.
    After several runs with the sweeper i conected the Renault Tool again - light is like before , goes on and after 2 seconds goes off
    Does anyone know how i can be shure that the immo is off ?
    THanks
    May 2013
    WATCH MY TUTORIAL
    I made ***8203;***8203;off real calculator on the car, touch it,
    One guy running the starter
    I pine key simultaneously.
    tested 100%
  10. The Following User Says Thank You to dell66 For This Useful Post:
    joe1953 (2nd March, 2014)
  11. #9
    Nov 2010
    Seafront
    Thanks Dell, but the car is about 800km away, will check your solution:-)
  12. #10
    Apr 2012
    Connect for Renault Tool
    SAGEM SAFIR (55 pin)
    Connect only three wires to decoder box: ground, immobilizer line and
    switched +12V. Connect decoder***8217;s red wire to constant +12V. Information
    about Ignition-ON is supplied to SAFIR via relay coil. Use any relay
    (automotive or not) with 12V coil. Select Advanced1 decoding type.
    2 -> Ground
    18 -> Ground
    1 -> +12V After Ignition (15)
    through relay coil to pin 48 !!!!!-> +12V After Ignition (15)
    TWINGO-43, CLIO-47 ->Fault lamp
    37 ->Immobilizer line
    after cut 37 pin
  13. The Following User Says Thank You to ivankurtev For This Useful Post:
    r_parev (27th September, 2015)
  14. #11
    Nov 2010
    Seafront
    Hi Ivan, i tried this with this pinout.
    I`m using the Renault Tool for the Fenix 5 and it works perfect but this one is other story-
    it does excactly the same after completing advanced 1 and standart mode - light goes on and after 2 seconds goes off like before.
    Im not sure if immo is off or not ...
  15. #12
    Apr 2012
    POWER SUPPLY more 12.5
    use only advanced 1
    cut immo line
    star the car
  16. #13
    Jan 2013
    Sagen Safir 2-55 pin
    A tried and tested solution:
    - Ground 2. 18.
    - Positive 1.
    - Feeding the UCE to 12V
    - Put the Pin 22 to ground for 5 sec. and repeat 5 times.
    - Cut pin 37.
    - Off Realty.
  17. The Following User Says Thank You to jcarlillos For This Useful Post:
    martinracing (11th May, 2020)
  18. #14
    Sep 2013
    Default IMMO 0FF ROVER 400 2.0 DIESEL MSB101150
    Hi!!
    I need help with solution immo off.
    Ecu is Bosh 0 281 001 956, 2002year tdi
    MSB101150
    Inside 24c04
    ROVER 400 2.0 TURBO DIESEL
    HELP ME!
    rover 2.0 24c04.rar
  19. #15
    Oct 2014
    Hi please I need pass to open this file
