here is your File. DPF Removed, you can check with Ols if you want.
Best regards
HSTYLE
HI,please can some one help me to make this ecu dpf off
its edc16c34:0281011633
i have tryed with ecusafe & volta but without success.
Best regards
Vladimirp407 edc16c34.rar
Best regards
HSTYLE
CiccioDOHC (8th September, 2013), Digamax (6th September, 2013)
Thanks, I will try and report.
ok please give Thanks when all is fine
kazoula55 (26th April, 2018), marwan akram (7th July, 2015)
Problem solved!
ECU SAFE work but I forgot to remove in BSI options that is engine with DPF (have to change that engine is without DPF)
Thanks to all
ecu safe not work for this ecu
the car will return
Not work for sure (ecusafe)
Im here to help and to be helped
Mate, did you charge somebody for this?
Ecu safe will delete dtc but FAP will be there! Car will return with problems and without dtcs how are you gonna solve it?
Be careful.
salut
Best option for edc16C34 PSa is 1 byteswitch off
Digamax (7th September, 2013)
NEW SMOK PSA,PSA XS EVOLUTION CLONE, KTAG 2.13 CLONE, CARPROG CLONE, GALLETTO 2 V50 CLONE, UPA-USB CLONE, AND BRAIN.EXE!!!
