Page 3 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 138
  1. #31
    Dec 2013
    Africa
    Can We Re Used VW Remots and transponder, Thanks
  2. #32
    You can reuse all remote from vw wich have megamos48. Transponder megamos48 is reusable only when came from car equiped with immo2 generation(circa 2001 year).
  3. The Following User Says Thank You to autofan1965 For This Useful Post:
    abvayani (30th April, 2015)
  4. #33
    In a van down by the river
    Quote Originally Posted by abvayani View Post
    easy answer - remote yes, transponder no, but you can remove old transponder and install a new one with ease.
    Touareg key is the exception - the entire key locks on them - key + remote and cannot easily replace transponder as solution.
  5. #34
    DK Veteran viejomatius's Avatar
    Jun 2009
    uploadfromtaptalk1435356230212.jpg hello, can someone help me, telling me if this dodge smart KEY is reusable or not? Thanks
    Work Smarter Not Harder
  6. The Following User Says Thank You to viejomatius For This Useful Post:
    softpoirl (30th June, 2015)
  7. #35
    antonypaul's Avatar
    Ford Mazda 8C re usable
    We live and work in a changing world. New laws are introduced that lead to the introduction of new policies.
  8. The Following User Says Thank You to antonypaul For This Useful Post:
    neverquiet (29th June, 2015)
  9. #36
    Member softpoirl's Avatar
    Aug 2014
    Quote Originally Posted by viejomatius View Post
    I have Couple of these DODGE SmartKeys But I still cant test if Reusable or not, who can tell me?
  10. The Following User Says Thank You to softpoirl For This Useful Post:
    viejomatius (30th June, 2015)
  11. #37
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    Dodge is reusable in USA, what is your market?
  12. The Following 2 Users Say Thank You to Automat For This Useful Post:
    softpoirl (30th June, 2015), viejomatius (30th June, 2015)
  13. #38
    Aug 2014
    Quote Originally Posted by Automat View Post
    i think are european ones, because frequecy 433 mhz, ID46,
    so not reusable?
  14. The Following User Says Thank You to softpoirl For This Useful Post:
  15. #39
    Chuichu village, AZ
    Is the same here in USA, 433mhz
  16. #40
    Jun 2013
    All Nissan ikeys are reusable
  17. #41
    Jul 2014
    Sofia
    Citroen C5 big old key with PCF7936 is reusable if transponder IDE cloned to TPX3 for example.
    Problem is hat ampula is bigger and doesn't fit in place of 7936 ...
  18. The Following 2 Users Say Thank You to RFRemotes For This Useful Post:
    Locksmith Hungary (25th September, 2015), mahmoud10th (7th March, 2019)
  19. #42
    Quote Originally Posted by softpoirl View Post
    Some are, some not. Depends on the chip inside.
  20. #43
    Quote Originally Posted by digikeys View Post
    2013+ in USA locks.
    Or, anything that requires 20 digit BCM. Always these keys lock in USA.
  21. The Following User Says Thank You to indienick For This Useful Post:
    Automat (10th August, 2016)
  22. #44
    Jul 2013
    Scotland. UK
    Quote Originally Posted by neno11 View Post
    I think ID40 transponder is not reusable but all three types of remotes with 2 buttons are (Bosch RK203, Kiekert 5442, Kiekert 5468). Must be the same type.
    Also remote for Corsa C, Tigra, Meriva with ID40 is also reusable.
    Some used genuine keys for Corsa B and Vectra B I've found have Opel type 40 which can 100% be re-used.
    I've scanned with ZedBull clone and see if it says 'Opel 40 WR' then you can use okay.
    If it says 'Opel 40 Crypto' then locked and useless.
  23. #45
    Denmark
    so remote is reuseabel but is locked to ide co if u clone to ex cn3 u will have a working key ?
