Results 1 to 15 of 29
    Jun 2011
    Default HELP TO PROGRAM KEYLESS KEY FOR NISSAN VERSA 2008 US MODEL
    hello friends
    pls i need help to program a key less for nissan versa 2008 i am usually programy nissan keyless using t300 or x-100 with success i already done many altima 2008-2009 and fx2009 but for those cars without start button i am not able to do i can program the key in the ignition but not the key less so help pls
    thanks in advance
  2. The Following User Says Thank You to elmaalouf For This Useful Post:
    topkeys (15th October, 2013)
  3. #2
    ray-ray's Avatar
    Easy my friend, sit in car and lock yourself in with the door lock switch. Next stick the key in the ignition "in & out" 6 to 8 time you will see the hazard light flash on the dash. Stick key in the ignition & turn to Acc >> lock or unlock using to door switch. Now press the remote button and keep your eyes on the dash should flash if it took the remote .
    Jun 2011
    Thanks for ur Reply I am asking about about the smart key not the remote is it the same way?
  5. The Following User Says Thank You to elmaalouf For This Useful Post:
  6. #4
    Apr 2013
    Ray ray he means twist proxy system keys
    In a van down by the river
    in USA you must unlock the steering wheel first...
    and if have wrong BCM 3 times it will lock you out for a while.
  8. #6
    Jun 2011
    So what ihave to do?
  9. The Following User Says Thank You to elmaalouf For This Useful Post:
  10. #7
    Jun 2011
    i unlocked the steering lick and do all and i try to program the key the car start but after cutting off for some minutes it cant start again
  11. The Following User Says Thank You to elmaalouf For This Useful Post:
  12. #8
    If you attempted to program 3 times before unlocking steering wheel, the BCM will lock. Must sit with car on for about one hour I think. THen start the procedure from beginning.
    Make sure you have the correct PIN before you begin....this car uses may use "old" or "new" PIN...need to try both.
  13. #9
    May 2011
    ive done some Nissan elgrands which are big vans and they have proximity and once I used a sbb but it didn't have elgrand on menu so I used Nissan marano but that only works sometimes , the other time I used x100 to punch in correct bcm code and then it unlocked the steering lock which allowed me to program the key which at same time programmed the proximity if it was close to key, and one other time a customer supplied chinese clone key and it worked for afew hours but the next day he went to start car and it would not start so I reprogrammed and same thing happened the next day, so I bought a genuine key and it has not failed so I always try to use genuine keys
  14. #10
    Jun 2011
    i was trying the pin code 5523 and it wasnt not giving me wrong code any way attached the bcm photo can i get pls the pin code old and new for this bcm to try them all and reply
    thanks in advance
  15. The Following User Says Thank You to elmaalouf For This Useful Post:
  16. #11
    siyadk's Avatar
    Dec 2012
    what......5523.. no way, who told you to try 5523, that is for old NATS system( esp if the key is 4d60). we are talking about the intelligent key here
    Try 8869(this is old pin)
  17. The Following User Says Thank You to siyadk For This Useful Post:
  18. #12
    Jun 2011
    The car is 2008 can it be the new pin?
  19. The Following User Says Thank You to elmaalouf For This Useful Post:
  20. #13
    siyadk's Avatar
    Dec 2012
    i dont know...u need to try
  21. The Following User Says Thank You to siyadk For This Useful Post:
    elmaalouf (10th September, 2013)
  22. #14
    Jun 2011
    ok will try tomorrow and reply thanks a lot and any idea if its the new pin how to get it?
    thanks again
  23. The Following User Says Thank You to elmaalouf For This Useful Post:
  24. #15
    Apr 2013
    The best place to get new pin is DK itself.....
    Post ur bcm code (cbad7) and ask for new pin
