Results 1 to 2 of 2
    Jun 2009
    Default Mercedes ML W164 Power liftgate Normalizing
    Hello there,
    I just have finished to retrofit a power liftgate on a W164, everything seems to be working fine except the opening with the key fob, but it open if I use the rear door handle.
    Every over closing /opening works fine by key fob or switches. the only problem is opening with keyfob. (door unlock and lock again but not lift)
    I have tried to denormalize the setting with DAS, but I can not denormalize the closing position, but I can denormalize the opening position.!!!!
    Hope someone can direct me to a working denormalizing/normalizing procedure.
    Thank you
    Jun 2009
    Quote Originally Posted by ladybreaker View Post
    Hello there,
    Thank you
    OK all sorted.
    My fault ,not to follow instruction to the letter
    I did not hold the driver door tailgate switch more than 5 sec as supposed to for normalizing.
    Every thing is working as supposed to and here is the link of the retrofit with a kick Mercedes ML W164 liftgate - YouTube
    By the way, I would like to see the tailgate to close if left open while driving away , and I think it can be coded in the rear sam, but DAS is asking for a password to enable this feature, can anyone assist on this?
    Thank you
