Results 1 to 14 of 14
Thread: burner?
    Jul 2013
    Default burner?
    what burner would I need to burn games, as I have one from a few year ago a liteon one, but do I need a different one now due to xgd3 or something?thanks
    Aug 2013
    Lite-On IHAS124B-19B BURN MAX CAPACITY DISCS FAST! | eBay. .................hope this helps or look onhttp://c4evaspeaks.com/lite-on-ihas-b-cross-flashable-drive-models-compatible-with-c4eva-ixtreme-burner-max-xgd3-firmware/
    Jul 2013
    Quote Originally Posted by adeys View Post
    cheers mate, that's probz the cheapest one ive found!
    Jul 2013
    do you think theres any point in flashing if the new xbox is coming out
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by tayyab95 View Post
    Thats your choice, anyway could be sometime before the xbox one is modded
    Jul 2013
    Quote Originally Posted by cunny View Post
    cheers mate, that burner is 42 quid, is there any other cheaper ones out there which will work?
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Yep there will be. All you need is1 compatable with c4e burner max payload
    Sent from my GT-I9305 using Tapatalk 4
    Jul 2013
    Liteon IHAP122-19 22x Internal IDE DVDRW Black Bare PATA + Software: Amazon.co.uk: Computers & Accessories this will work wont it? if you can check it out for me .. I think I will flash better than spending hundreds on games, are you upgrading to the one.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    There is a known comapatable list on c4espeaks and no i wont be i dint play on tbe 360
    May 2013
    PC World have the HP DVD1260i which is crossflashable with the BurnerMax Software for under ?20
    HP DVD1260i Internal SATA DVD Writer Deals | Pcworld
    Jul 2013
    what do you mean its cross flashable, that's cheap im going to purchase, just don't know what you mean by that, cheers
    Oct 2011
    Quote Originally Posted by sattv5 View Post
    be aware of this when purchasing to ensure that the version you're getting has the newer "B" chipset.
  13. #13
    Jul 2013
    is that the correct one then> can you find me one cheers
  14. #14
    May 2013
    Here's the Instructions you will need. You can check the drive before you buy it from PC World to make sure it is the B revision
    It was the B revision a couple of months ago that they stocked
