no problem for this dpf.
Marca di derivazione del file: Ford / Ford USA
Modello di derivazione del file: KUGA
Tipo di derivazione del file: 2.0L TDCi 100kW/134HP SID 803A
Protocollo di derivazione del file: FLASH_0155 FORD SIEMENS SID803A/SID202
Numero Hardware: CAFR1B00FR1B000
Numero di programma: 10154053AA
Hi, is it possible that after deleting DPF both ECU and mechanically, the car every 15 days is the diesel fuel in the oil pan? is a problem of DPF OFF?
Thank you.
KUGA.rar
"IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
Yes fuel get in oil because of DPF.
filter 100% empty? if so file is not properly done. you may still have postinjection active!
seems a swiftec file
it don't work, tested! postinjection are active with that file
ProTuner since 1999
