Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    I read and write m1.5.5 from alfa 156 via pin connection without boot mode, and work make immo off with immo universal decoder 3.2, is tested from me
  2. #17
    Oct 2017
    Hi guys,
    I wanted to program my ECU M1.5.5
    of an alpha 156 1.6 Twin Spark 120CV
    inserting the 1.8 TS 144CV engine file.
    With the ECM software the memory addresses are all correspondent;
    I wonder if it is possible to do this programming or if I can do harm ...
    At home I have an ECU M1.5.5 1.4 TS 103 hp and its ECU CODE,
    I could possibly do the tests on this?
  3. #18
    Oct 2017
    nobody knows anything?
    Inviato dal mio SM-G361F utilizzando Tapatalk
  4. #19
    Above sea-level
    with valid key you mean? Valid to immo? I want to replace ecu because of a problem with it and keys are fine.
    Quote Originally Posted by redtop View Post
    As I wrote begore in this thread, there is no boot mode pin. But pin 10 in the ECU is a "update software enable" pin (+12V).
    If the ECU is in the car with the immobox and a valid key you can update the ECU this way. On the bench you need to open the ECU and trick the ECU that it is virign as described earlier.
  5. #20
    Oct 2017
    I did the test: perfectly successful programming ... Let's see in the coming days if pin 33 works for variable geometry ....
  6. #21
    Dec 2017
    I got an alfa romeo gtv with ecu m1.5.5 which was bad and a new one purchase, thus need to be learn to immo.
    I have read through your post, learn a lot but a bit confused
    ***Suppose I wand to put the ecu virgin (assuming it would be in self learning mode and thus auto register immo data).
    -if an off vehicle I would have to open ecu connect ecu to -/+ and add ground to boot pin inside the ecu( but for how long to completely virgin it)
    -if an on the vehicle, add +12v to pin 10 to boot and virgin the ecu( for how long)
    Thanks for your assistance
    Envoyé de mon HTCD200LVW en utilisant Tapatalk
  7. #22
    KILL_THE_IMMO's Avatar
    spain
    why complicate the jobb????
    --------HELP OTHER TO BE HELPED--------------
  8. #23
    Oct 2017
    check out the discussion IMMO OFF ALFA 156 1.6 16V, there is an excellent procedure ...
    Inviato dal mio SM-J530F utilizzando Tapatalk
  9. #24
    Dec 2018
    My friend you can do it very easy on the bench....I made so far more than 20, all of them out of car. Just you have to know what exactly must connect and where and of course to use official programs not clones... For example Galeto its a toy, not a program. As concern the .BCB file this is only for Titanium decoding in order to recreate the checksum.
  10. #25
    Nov 2019
    Egypt
    hi dears
    It is possible to ask those who are able to work on bosch m1.5.5 to fully explain the method from the first connection method and the way to read and write on it
    Thank you all
  11. #26
    Oct 2017
    Quote Originally Posted by hany50 View Post
    hi dears
    Thank you all
    the file cannot be read ... you must have the original file that you will modify and reprogramme on the ecu. To reprogram you have to give + 12V to pin 10 to enable programming
  12. #27
    Sep 2014
    [QUOTE=redtop;2586107]Hay mucha información falsa sobre el M1.5.5 en Internet, incluido este hilo.
    Este es un texto que preparé para un Alfisti hace algún tiempo:
    Hay información sobre el M1.5.5 en Internet, pero gran parte de ella son malentendidos, así que me tomó algo de tiempo juntar toda la información. El M1.5.5 no tiene un verdadero modo de cargador de arranque. Solo se puede actualizar a través del software de la ECU, no directamente al microcontrolador como ME3.1 o ME7.3.1. Eso significa que si algo sale mal durante la actualización, o si carga el tipo de archivo incorrecto, su M1.5.5 será destruido. Además, no puede leer el M1.5.5. Debe encontrar el archivo correcto en Internet antes de poder convertirlo en virgen o immo off.
    Al cargar archivos al M1.5.5, el archivo debe estar en formato BCB. ¡MUY IMPORTANTE! Puede saber si el archivo es BCB abriéndolo en un editor hexadecimal justo al principio, debería leer "BCB Type1 (C) R.Bosch GmbH'". No hice mi tarea correctamente y cargué un archivo BIN, y ahora mi M1.5.5 experimental está muerto.
    Para poder actualizar el M1.5.5, debe estar en el automóvil con el immobox correcto conectado, O debe engañar a la ECU para que piense que es virgen abriéndola y conectando a tierra una determinada almohadilla en la ECU. Ahora, esta es una ECU híbrida, por lo que es muy fácil dañar los cables de unión delgados si no tiene mucho cuidado. Hice una plataforma especial (ver imagen) para conectar a tierra la plataforma.
    Para hacerlo virgen o immo, primero carga un archivo especial que cambia la eeprom (a menudo llamado archivo COD). Luego vuelves a flashear la ECU con el archivo original.
    [/CITA]
    Heyy friend ! i need your help, please deleted message or send me email please,
