Results 1 to 4 of 4
    Dec 2018
    Europe
    Default Need full bdm file for passat B6 2,0 TDI 2008
    I need full bdm file for ECU SIEMENS SIMOS 5WP4 PPD 03G906018ER 1252 SW 6576286333 if someone can help me.
    Thank you very much
    Best regards.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by nagold View Post
    Thank you very much
    Best regards.
    have only flash found...
    maybe itīs helpful...
  3. The Following 2 Users Say Thank You to figani For This Useful Post:
    khaleddaddi (16th September, 2020), nagold (17th October, 2019)
    Dec 2018
    Europe
    Thank you !
    I'll try
    Dec 2018
    Europe
    The problem is solved. Once again, thank you for your help.
    Someone tried to do dpf-off and bricked the ecu, probably when it uploaded the modified file through the obd port without crc correction or corrupted, who knows !
    Now everything is ok, the car starts, dpf-off works perfectly. I just needed BDM flash file for reinstalling factory operating system for recovering bricked ECU
    Best regards
