Ive only got all the channels back
you serious?
Yep got em all. And new ones bt1 &2 and they are not scrambled
Ive took pics of all the figures .
Ill post what ive done...
cactikid (18th September, 2013)
did u go to pals house to sort this?
I found em using tivo sub box.
Goto settings diagnostics...all the digits...
Scroll down
It will say tuner 0
603250
Qam 256
Manually add this tp to kv with sr of...6952
Goback to tivo. .
Theres two more tuners...
Add em.
6952
Goto kv...manual scan
On the 8tps these come up "fail"
Try one of the 3 you just entered. ..
For a start it will scan for longer...
One or two may fail.
I think it only has to find one channel amd your tp list comes up "Litchfield"
I then auto scanned again.
It found shed loads.
Let me know...im shaking
ASEK (18th September, 2013), Wellinever (18th September, 2013)
Nope..at my house.
The settings arnt exact above off tivo. I think its 610.250
well done hope it helps others.
ffs don't rescan or delete
154.250 6952 qam256
Is one of the 50 odd tps
Ill be back in morning. And try and relay more exact figures.
Hopefully there will be sum feedback that its worked elsewhere
Goodnight
I wont
Ok. Factory reset..
Add tp to ntl
602.250 sr 6952 qam 256
602.250 sr 6887 qam 256
610.250 sr 6952 qam 256
610.250 ar 6887 qam 256
Try autoscan with these extra tps.
I did manual on one of em and got a few fta channels. Rest was history.
If not manual scan individually.
Please can someone verify
Rich
Digicom (18th September, 2013)
monkeyb0yuk (18th September, 2013)
well done mate f all to do with latest s/w then more to do with the changes in qam rate gone are the days when one area had one symbol rate only so when you are factory resetting the tps listed are 6.887 and hardly any channels are using this rate anymore..
so nothing to do with service providers counter measures..
but pleased someone from that area as actually spent a bit of time experimenting for the benifit of others
Dont worry guys...a channel list will be archived or saved somehow so at least it can show the info.
Can I upload it here.
At work till 5 so cant do much till then.
The picture looked vg for sdef on the channels I saw...no glitching in the few mins I watched em before going to bed
I just want confirmation that someone else can verify my work around ... anyone?
