    Default Problem Reading Bosch EDC16C39 via BDM with FG Tech V48
    Hello Guys
    I have a Problem, i must do a EGR OFF. ON a Bosch EDC16C39 from Alfa 159 2.4 JTD 20V.
    So i try the first Time with the BDM. I get the ECU ID when i pusch the Connect button in FG Tech Software.
    Then i try 2 read out the External Flash, Also this works and the reading Process beginn, but after 10 min Reading, The FG Tech Software crash and dont read the file till the End.
    Somebody had the same Problem?
    I have the FG Tech with One LED, and its the first time that i have a problem with this Tool to read a ECU, also Boot Mode Reading works fine.
    Please help me guys.
    Thanks to all Members
    greetings from Switzerland
    kugglefischer's Avatar
    In an Ecu
    ive had problems with this chna made fgtech too......
    The difference between men and boyz...Is the price of there Toyz.
    LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
    DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
    Nio's Avatar
    Quote Originally Posted by bambula tuner View Post
    Hello Guys
    If you do not need to have this problem must buy original tools. Generally clones have problems. I think in his case is power problem. Not good hardware. Regards.
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
    Hello guys
    I have the solution i got the new fg tech v50 in black box. This one has another hardware inside and works perfectly now. But now i have another problem this Ecu dont start up now when i put it in the car the Mil lamp is off and i cant comunicate with the ECU. Sombody has the same problem?
    With the v48 i only try to read the external flash no writing and now i have the problem is it possible the ecu is damaged now?
    Thanks to all
    up to now has not spent too much.ma from now on
    Quote Originally Posted by koyot View Post
    How do you mean that. The New FG Tech V.50
    cost only 80 Dollar.
