Results 1 to 8 of 8
    BestElectrical's Avatar
    San Diego, CA, USA
    Default 2013 Ford Focus Key programming
    Hello, I am working on a 2013 ford focus, I need to program smart keys. Does anybody know a correct procedure of programming keys when all keys were lost?
    The problem Im having is that first part programs fine, the key chip in steering column, but the second part, the smart remot does not program. Im using IDS v 86 with original VCM2. The program tells me to press and hold unlock button for 6 seconds. IDS time runs out and it tells me it was unsuccessful. This is a second ford focus that I am having same issues.
    Please share if you know how its done.
    Thank you.
    BestElectrical
    drakov's Avatar
    Aug 2008
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  3. The Following User Says Thank You to drakov For This Useful Post:
    BestElectrical (19th September, 2013)
    keysph's Avatar
    Feb 2011
    You must have at least two keys to program.
    AD states that the unlock button on the remote must be pressed for 15 seconds when prompted.
    LE:
    From the video posted on their site it say that when programing a remote the others to be coded must be outside the car.
  5. The Following User Says Thank You to keysph For This Useful Post:
  6. #4
    San Diego, CA, USA
    Thanks for a quick reply, Im working on a North American model, it is different from euro model. If anyone done one of those please share the info.
    Thank you!
    BE
    keysph's Avatar
    Feb 2011
    No separate procedure for that in that case
  8. The Following User Says Thank You to keysph For This Useful Post:
    cole_mcs (7th May, 2014)
  9. #6
    San Diego, CA, USA
    2011 and 2012 model keys are different from 2013, I have done those before with no problem. It is only the new models that I am unable to do for some reason...
  10. #7
    Nothern California
    i m trying to program regular key ford focus 2013
    can ford ids program keys for ford n maxda
    Knowledge is the Key
  11. #8
    Jan 2011
    2013 ford U.S.A SMART KEY PUSH BOTTOM, i have the same issue i can not program second part of the key, wireless , key are original fords 2 smart key, im able to programming it in hole slot but wireless i got not succes, i press the unlock botton when original scan ford scan tool display, and no success , does anybody know correct procedure, thanks,,
