Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 69
  1. #16
    Sep 2013
    Quote Originally Posted by kritikos View Post
    Thanks i will check it,and let you know
    Thank you............everything ok thank you for your help very good site
    have good day
  2. #17
    Dec 2010
    Whats the difference between softcamMotor and Glenn_911 TM softcam for all?
    Should i use Glenn_911 TM softcam posted today ?
  3. #18
    digicon's Avatar
    Quote Originally Posted by imsraj View Post
    All the same really just use the latest one posted as this will have updated keys
  4. #19
    Dec 2010
    Anyone have the list of scrambled channels on hotbird that the softcam opens ? does it open JS+ 1 to 4 or some of the french channels.
  5. #20
    digicon's Avatar
    No is the answer to that sorry
  6. #21
    Oct 2011
    Hi. On Hotbird it opens up RAI Sport1/2(when scrambled), TV GLOBO and MEZZO. If you have a 1m dish motorized you can open channels on 1west(not many), 4.8 east, 7 east(many channels) , 19.2 east, 23 east and 39 east. Also plenty of footie channels and other channelsopened on different sats with BISS keys.
    Regards.
  7. The Following User Says Thank You to Nutsandbolts For This Useful Post:
    mdt (3rd October, 2013)
  8. #22
    Oct 2013
    Sorry but I am very new to all this, I have a Technomate 5402 HD M2 and I would like to receive TNT SAT channels on Astra 19.2E, I have installed
    patch Phantompatch-TM5402HDCI_M2_ALL_107p_28-08-13 and SoftcamMotor.key but still get scrambled channels, are these the latest versions of
    patch and softcam keys
    Also do I need to do anything "special" to use the keys or should it work automatically ?
    Best
  9. #23
    digicon's Avatar
    Have you tried the latest Patch version for your M2 Receiver which is 109p:
  10. The Following User Says Thank You to digicon For This Useful Post:
    agathe79 (12th October, 2013)
  11. #24
    Oct 2013
    Many thanks, that worked a treat, Best Wishes
  12. #25
    Hi lads,
    on Manual insert( remote control code: 8280) Biss key, what line do insert the keys? there 1 to 40 line in box? I inset key fist line but did not work!!
  13. #26
    digicon's Avatar
    If you are entering Biss keys into the 8280 menu then you must first make sure that your receiver is tuned to that channel with the scrambled message, Then enter the 8280 menu and use any line you wish to enter the key once done press exit at this point the box will ask you to save select yes and thats it your done. If the channel does not pen then there are 2 possibilities 1. the key entered is wrong or 2. The key has now changed
  14. #27
    Thanks replay, I have tried latest keys!! how often the keys are change?
  15. #28
    Oct 2011
    Quote Originally Posted by ky1 View Post
    Hi.. How long is a piece of string??? Nobody knows when keys change apart from program providers. Keys can last from 5 minutes to 5 years or more. What channel are you trying to open using BISS keys??.. If its on 28.2 east satellite then you can forget about it as this satellite is out of bounds with softcams/BISS etc. There are many channels opened with BISS keys but you will need a motorized system with a 1m dish in my opinion.
    Regards.
  16. #29
    I understand mate, thanks for heads up!!
  17. The Following User Says Thank You to ky1 For This Useful Post:
    deeview (16th October, 2013)
  18. #30
    Feb 2013
    yorks
    19.2 east in that update thanks.?
