Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    aftermath's Avatar
    Mar 2008
    Default IPBox NLB Images
    Cuberevo NLB 8421 v1.110
    Prepared by : Dexter
    Release date : November 9. 2008
    Changes:
    * fixed: DGS application patch to keep EPG when changing TP, DGS delete them.
    * fixed: card reader enabled from boot again.
    * updated: NL language files (Gman2006)
    * updated: USB scripts updates
    * update: nlb panel v1.36 emu changing works now.
    * - option to set changable delay during boot with newcs
    * - Some cards requires longer initialisation than others.
    * - Those without should just use like 3 seconds.
    * updated: Webepg v0.6 now works with patched DGS application
    * - option to dump favorites as webepg.list
    aftermath's Avatar
    Mar 2008
    Default IPBox CLi Image
    I must personally Thank Satman and the Cli Team for my Favourite image at the moment. The Web interface on this image is the best one available.
    Cli-3.0.0- Based on ABCOM8340 for 9000/revo
    **** THIS IMAGE CONTAINS NO KEYS ****
    **** Cli Team ****
    ip9000/cuberevo version
    PLEASE NOTE:: YOU CANNOT USE THE SATKINGS CABLE ADDON V1 WITH THIS DUE TO OLD DATABASE VERSION.. PLEASE BACKUP YOUR /var/keys and /var/scce from your old image before flashing!!
    I will release a new cable addon with latest db revision soon
    NEW RELEASE r8340: Added or improved Function
    1. Add video resolution in Additional banner
    (press "i" button two times)
    2. Show the kinds of supporting format for video plyer
    (divx, xvid, mpeg, mpg, trp, vob, avi)
    3. Fixed the bug staying power on without signal
    RELEASE r8314: Added or improved Function
    1. Fixed Swaping PIP
    2. Fixed Audio Language Preferences.
    3. Fixed an combination of USALS and Diseqc
    NEW RELEASE r8264: Added or improved Function
    1. The video player(Divx 3,4 and xvid, mpeg 2, H.264)
    : video player can support some file formats such as *.avi, *.mpg and *.mpeg.
    you have to change the extention as *.avi, *.mpg and *.mpeg before playback.
    press pause : pause state
    Pause> pause : pause state
    Play button only can be exit from pause mode.
    Sometimes, If the file needs higher class CODEC than current one, it may be not played.
    If the file itself too high bitrate, it may be not played.
    The version of Divx CODEC more than 5.2 doesn't support it.
    2. WebTV on webinterface
    : First of all, you have to install VLC Player on your PC.
    It's tested on Firefox and Internet Explorer 7.
    Javascript is required.
    Streaming works for 720p channels, but for 1080i there is not enough network bandwidth.
    USAGE: Surf to
    http://(boxip)/webtv/
    3. ITV HD(Astra 28,5)
    : it should use Advanced Search menu with manually (3401 VPID, 3402 APID, 2326 PCR PID)
    FlySat Eurobird 1 - Astra 2A/2B/2D @ 28.5/28.2? East
    4. improved to related USB HDD
    : 1 channel recording in a TP and 1 recorded file playback or 1 another channel watching in the same TP.
    5. improved channel zapping speed
    6. Solve the bug of the USALS
    7. Solve the bug of the Diseqc 1.2.
    8. Support HDD sleep
    : If select timeshift off, HDD willgo sleep mode after 3 minutes.
    9. Update DB for DVB-T and DVB-C
    : Ireland MMDS(Terrestrial), IRE6887 Quick(Cable), ENG6952 Quick(Cable)
    10. improved to related plugin
    11. channel list of Grid EPG follow channel sorting
    12. bug fixed static IP
    13. Added FAST SCAN function for Benelux
    known issues
    : WSS in Recorded Files.
    : HDMI with compressed Dolby digital audio
    : DVB subtitle
    Above all, we can confirm the effect in the DGSTATION enviroments.
    We cannot be sure of the same result.
    If not so, contact with us.
    e-mail:
    support@dgstation.co.kr
    Thank you.
    Mods by Cli TEam:
    DGS Web interface + Cli interface both merged into one now. ( webtv function and much more on dgs interace ) PLEASE USE FIREFOX
    *Update UK Cable Database
    - Add missing frequancy
    - Add England 6952 Quick scan
    - Fixed DVB-T Ireland
    *Working German Translation from Byti
    * Working French Translation from old image
    *Added missing HD frequancys on 0.8w and 0.5e
    *Inadyn Support, please set config in /var/etc
    *mgcamd/evocamd/mbox/incubusCamd support from web interface
    *update Keys at touch of a button ( need to add Url to /var/etc/Keyupdate.url
    *Cron Job Support - add crontab file and look in var/cron
    *Email 0.3 plugin - Thanks to Kneubi
    *script plugin - thanks to Kneubi
    *games_plugins(tetris,sudoko,pong) - Thanks to Neumoteam
    * RED.sh for easy change of red button use - current update keys
    * green.sh for easy change of green button use - Restart Cam
    *-yellow.sh for easy change of yellow button use- current show ECM
    *-Cli Modified Kernel for network bug
    *-Fixed terminfo definitions for top command
    ****Known issues still to resolve
    - EPG Still wont save to a database so only loads current transponder to memory
    - Esata drive is recommened for recording.( not usb )
    - Cli Web interface has issues with internet explorer PLEASE USE FIREFOX for web interface full functions
    - will add working openvpn on next release
    ****We promise some of these are DGS issues and we need to wait on them fixing, but hopefully very soon
    Satman + Cli TeAm!
    aftermath's Avatar
    Mar 2008
    Default IPBox Official AB Image
    AB_9000HD_271008_r8340b
    aftermath's Avatar
    Mar 2008
    Default IPBox Official Cuberevo Image
    aftermath's Avatar
    Mar 2008
    Default NLB8478 for 910 and 900
    Working Links here
    NLB8478-910-v1.2 for IP box 910
    http://rapidshare.com/files/168818168/nlb8478-910-v1.2.rar
    and for NLB8478mini_v1.2 for IP box 900
    http://rapidshare.com/files/168821186/nlb8478mini-v1.2.rar
    aftermath's Avatar
    Mar 2008
    Default Cuberevo Release 8611
    Release date : December 10. 2008
    Changes:
    * added: NFS mount replacement for HDD SD media recording folder
    * --------: - can be enabled disabled under IP9000 -> change NFS/HDD media in webif.
    * - Thanks to DGS for assistance on kernel fix.
    * - HD Recordings works too, but will studder! so you are warned.
    * fix: NFS mount on boxes without internal hdd.
    * fix: Slow NFS mount fix (thanks to semack for the help).
    * added: - delay option in panel for Nagra3 cards.
    * added: - Germans with nagra card should use 20 seconds and it decodes at bootup
    * added: ushare for sharing through UPnP protocol (like to PS3) Thanks to Kneubi
    * -----: enable/disable/restart in Webif->system options
    * added: Option to run boot scripts from /var/etc in hotfix situation.
    * plugins: bitrate 0.0.2 and favpip 0.7 .
    * updated: newcs.xml added boxkey code to support German *** cards.
    nlb8611-v1.21
    WEBIF
    login: root
    password: relook
    First time boot with Remote still not working, not fixed yet.. sorry!
    Reboot at language screen and all is okay.
    http://rapidshare.com/files/172079599/cuberevo_r8611.zip
    aftermath's Avatar
    Mar 2008
    Default NLB8611-v1.21
    http://rapidshare.com/files/172469456/usb_all_noboot_nlb8611-v1.21.rar
    AbCom IPBox9 Series / CubeRevo nlb image
    Unofficial Custom release
    **** Updated: 10 december 2008 ****
    Features of NLB Image
    - delay option in nlb panel for problems with newcs init card, such as nagra3 cards.
    - Germans should set delay to about 20 seconds, so it will decode at bootup
    - without need to restart cam.
    - NFS mount as replacement for internal HDD (for SD recording only)
    - HD/MPEG4 recording works too, but will studder as MPEG4 can be
    upto 20Mbyte/second and with 100Mbit network card, it will never work good.
    - Onscreen panel for stop/start of most features found in webif.
    - Internet update function for webif and panel for now.
    - Customized startup, faster load times
    - Added support for
    external usb serial port (PL2303 USB-Serial)
    - Added binary utils
    - ssh / scp / sftp (client tools)
    - fw_printenv / fw_setenv (uboot environment see/change)
    - strace
    - cron daemon
    - alternative thttp daemon (not used)
    - Emus included (in /data folder, Read-Only)
    new updates should be placed in /var/bin .. (see name in [] )
    - [newcs] newcs 1.62 (newest 23.10.2008)
    - [incubusCamd.sh4] incubus 0.5 (newest 22.10.2008)
    (DISABLE TIMESHIFT TO MAKE THIS EMU WORK!)
    - [mgcamd130] mgcamd 1.30 for nordic viasat users
    - [mgcamd] mgcamd 1.30d
    ( use 1.30 if you are viasat nordic user,
    for faster channel switching)
    - mpcs 0.9d
    - [mbox.sh40] mbox II 0.4 Build 005 (3.10.2008)
    - [evocamd] evocamd
    - all key files should be put into /var/keys folder.
    - Samba (Windows networking sharing)
    - ftp / telnet / ssh server
    - terminfo for top (primarily)
    - USB multiboot (see below for details on how to use it)
    - supports all_noboot images too.. (except AbCom image)
    - WebIf (details below)
    - Bootscript for loading at every startup
    - /var/S59_bootscript and remember "# chmod 755" on script
    NFS Media setup howto
    Its not possible to configure a NFS mount in dgs application as DGS do not support NFS,
    but in background this is handled so do not worry about choosing CIFS setup in mount manager.
    the line in your /var/mount_manager_fstab should look similar to this.
    cifs /mnt/nfs 10.1.12.100 /var/nfsmediashare dexter dexter NLBshare Disconnected
    IMPORTANT: current release has one requirement "rule".. part of NFS sharelocation needs to include nfsmediashare ,
    so your share can be /media/nfsmediashare or /movies/nfsmediashare or similar.... just remember to include that name in share.
    after you configured this, you also need to enable in webif, and choose IP9000 -> Change NFS/HDD media.
    you can edit the file and reboot box or you can configure in dgs application, but do not press "connect",
    it will not work like this.
    After you enabled it in webif, and configured the line in your mount manager, you can reboot and at next
    boot you got /media mounted from your NFS server.
    For this wondering why CIFS is not supported, its because CIFS do not support directio and also speed of CIFS
    is worse than NFS.
    WebIf
    The webif is your control center of the NLB mod image.
    Default login is: root and password: relook
    If you need to update access table for ip addresses allowed to access webif, please
    edit the /var/etc/httpd.conf
    You find a line here ie.
    A: 192.168.
    Enter your network segment here, example
    A: 172.24.
    or a specific public ip
    A: 212.242.1.12
    Save file, and reboot box, and you got access to the webif.
    - System information
    * Processes - List current applications running on IPBox
    * Change SWAP HDD - Activate Swap or disable it.
    * CPU Info - get IPBox cpu info details
    * System Boot information - output of "dmesg" startup of box.
    can be used even if your box shows "PANIC".
    - System options
    * restart samba - restart windows sharing service.
    * Samba status - Activate or stop samba/windows sharing services
    * Change HDD filesystem - Choose between ext2/ext3 or existing.
    ext2 filesystem will run FSCK (filesystem checks)
    ext3 filesystem skips FSCK
    * telnet status - Activate or stop telnet service
    * ssh status - Activate or stop ssh service
    * ftp status - Activate or stop ftp service
    * Restart box - Reboot your box
    - Firmware options
    * Upgrade FW - Upgrade firmware from img file in /var or /media folder.
    transfer .img file to /var or /media folder and select this option
    to upgrade firmware.
    * Multiboot - Read below for details
    - USB options
    * SWAP - activate or disable swap on USB key
    * Format USB - format a usb pendrive/stick for use with box
    - and for multiboot setup
    * NOTE: USB Stick will be mounted on IP900 as HDD if above 2GB
    And this means it cannot be formatted in webif on ip900.
    * Mount USB - mount a USB stick on box, to access files on it
    * Copy /var - make backup of /var to your usb stick
    * backup db.dat to usb - copy your db.dat file to your usb stick
    * restore db.dat from usb - restore db.dat (will be named db.dat.edited)
    requires reboot to take effect.
    * List contents of usb - list contents of usb stick, if mounted.
    - IPBox options
    * HDD/NFS media folder change - NOT ENABLED AS OF THIS WRITING!
    * Change Fan - enable/disable fan in Ipbox.
    * Show time in led - activate Time in VFD display.
    * Change led - Change VFD brightness (0-7)
    * stop sbox at next boot - will disable start of "satbox" application at next boot (debug)
    * Assign color button - Read/Yellow/Green buttons can be assigned functions
    most options above + more described below here.
    WideScreen - stretch tv picture on TV's that do not do it automatically.
    ecm info - show current ecm info on tv
    hdd temp - Show HDD temperature on tv display
    restart cam - says what it does
    stop cam - -- !! --
    Soft updater - run your /var/bin/soft script
    * Change skin - Change the look of your menus in DGStation satbox application.
    * Skin: Crash Blue
    * Skin: Crash Grey
    * Skin: Crash DeepBlue
    * display HDD temp - show current temperature of HDD
    - Emu
    * Change mbox status - Stop/start mbox at next boot.
    * Remember to use "change emu" also to choose this one
    * Change mgcamd status - Stop/start mgcamd at next boot.
    * Change emu - Select between evocamd / mgcamd / mbox , to be
    automatically startup at boot.
    * Stop Emu - Stop running emu.
    * Restart Emu - Restart running emu.
    * Change newcs status - choose to stop or start newcs at bootup.
    * Change newcs config - Choose between both/upper/lower newcs default config
    - this will overwrite your existing configuration.
    * ECM - Show current ECM of provider.
    * Mgcamd shares - show current connections
    * Card stats - mgcamd status
    * Info about cards - if gbox peer enabled, shows current list of cards.
    - Keys update
    * Sxxxx.Kxx Update
    runs your /var/bin/soft script
    EMU DEFAULT CONFIGURATIONS
    mgcamd
    included is a default config to run with newcs and
    use internal card readers (activated default)
    originally tested with Viasat and CanalDigital cards.
    mbox
    Tested with CanalDigital card.
    Now includes 32100.list, 32101.list with default all channel opened.
    evocam
    is included, but there are no defaults for anything configured!
    incubusCamd
    is included, but defaults are still in testing and this is a beta release of cam.
    USB MULTIBOOT
    - Multiboot feature gives you the option to boot off a usb pendrive/stick, so you can
    more easily place as many files you wish into the root file system, with the only
    limit of the usb filesystem size.
    - It also uses the USB pen for /var storage, so each image will have its own setup.
    - Removing the usb pen, will cause box to boot flash image.
    - USB pen should be formatted in webif, before use
    - other USB pen cannot be used/formatted in webif, when you are running multiboot.
    Instructions for usb multiboot
    - Format a usb pen in webif (USB Options - Format USB)
    (old formatted usb sticks from 8022 and down needs reformatting)
    if used in DGS box during mp3 playback or photo album, it will not work.
    - Wait for an OK from formatting (takes 30-60 seconds depending on size)
    - Placing firmware on usb pen procedure
    - * For /media folder
    - with ftp copy an .img file to the /media folder
    - Only DGS / SifTeam / NLB images will work.
    - * For /mnt/usb/usb0 folder
    - mount usb pen in webif (USB options - Mount USB)
    - select Firmware Options - Multiboot
    - in field "Enter name ...." write a suitable name for image
    - in "Choose file to put on usb" select image to put on usb
    - in front of img file you can see location of file.
    - Press "extract" to extract image to usb.
    NOTE: IF NO USB PEN IS INSERTED YOU DO NOT HAVE OPTION TO INSTALL IMAGES!
    OR FORMATTED CORRECTLY, ie. Windows formatted pen will NOT work.
    - when finished (takes 2-3 minutes), reselect "Firmware Options - Multiboot"
    - In bottom "Select USB bootimage to use" you can now see your image.
    ? if it is not shown and extract failed, make sure your usb was
    formatted with a unix fs, ie. using format usb in webif.
    - You can choose to "Change" and mark which image to load at next boot
    or
    - You can choose to "Delete" firmwareimage from usb.
    - Selecting "Flash boot" will make box boot your flash / disable usb boot.
    - Reboot box to start usb firmware.
    Junior Member balikuyu's Avatar
    Jul 2008
    Aftermath Dude
    Sorry for not keeping up, but the version before NLB 8421 v1.110 didn't solve the epg problem for me (I didn't install v1.2), but it is very fast on channel change and no freezing a good image does this latest one resolve it?
    P.S. Guys will DK have a IPBOX /Cuberevo downloads section available I keep checking the posts for new downloads but I think it would be better to have a dedicated section for us HD geeks pleeeeasee.
    Cheers Bali
    There will come a time in history when mankind will be enslaved by the machines........... only a few will resist........It is not the answers that drive these people but the questions.......and the ultimate choice to make a stand against tyranny.
    aftermath's Avatar
    Mar 2008
    Default Abcom Official Release v 8630 for IPbox9000
    Official ABcom r8630 for IPBox9000HD
    AB r8630_151208_change log
    Bug Fixed :
    - PVR trick/record length bug
    - Fast scan bugs
    - crash problem When schedule recording
    - Nova HD EPG fixed
    - crash problem after press EPG button in Bulgarian menu
    Changed/improved :
    - add DVB and TTX subtitle support
    - Change Date format(dd.mm.yyyy)
    - add support for DreCam - You need installed "addon_DreCam_support...."
    - improved LAN connection speed (now is speedy)
    - for 9000HD : add post descramble option with CAM?s
    You can record scrambled channel and descramble before playback:
    Go to record files list, select scrambled record, press Record button, select CAM with card
    for descramble and press OK. STB create new descrambled file.
    - support youth protectioon
    - support nfs mount recording
    . remove access to /media/
    . mount remote directory to /media
    . mount -o nolock,soft IPIRECTORY /media/
    - display video resolution in info banner
    - upgrade Finnish, Russian, Polish, Bulgarian, Czech and Slovak languages
    - Support HDMI with compressed Dolby digital audio
    - Add Front scroll function when channel name is long.
    - When schedule recording, remove timeshift buffer.
    - new AB setting for Astra 19.2, HotBird 13 and Astra 23.5
    - installed plugins: mail, weather, bitrate , tetris, pong, sudoku, favpip
    instalation
    copy "addon_version-9000HD_sh4.ipk" to /tmp
    connect to box with webinterface ( write IP adress of your box to internet browser)
    use login/password : root/ipbox
    go to menu addons
    select manual
    press install
    wait for STB reboot
    Abcom Image v8630 for IP box9000
    http://rapidshare.com/files/173975135/Abcom_official_image_v8630_for_IP9000.rar
    Drecam addon
    http://rapidshare.com/files/173973017/dreCam_version-9000HD_sh4.rar
    Drecam and Mgcamd 1.31 addon for IPbox9000
    http://rapidshare.com/files/173975776/DreCam_addon_with_mgcamd_1.31_version-9000HD_sh4.rar
    V.I.P. Member sotiris70's Avatar
    Nov 2008
    CubeRevo nlb8611 to nlb8630-v1.21 quick upgrade
    WEBIF
    login: root
    password: relook
    This ONLY WORKS ON NLB8611 firmware..and takes/requires 2MB in /var
    copy binary "sbox_update" included into your /var/etc
    with ftp.... in your favorite ftp application (ie. totalcmd) type
    chmod 755 sbox_update
    and reboot box and you are upto 8630 edition.
    Jul 2008
    Still says NLB8611 on startup on LCD is this normal?
    Cheers
    aftermath's Avatar
    Mar 2008
    Default Sifteam Images
    Sifteam Image 8580.
    will upload some info on the changes on this as i get it.
    http://rapidshare.com/files/175912863/SifTeam_8580.rar
  13. #13
    aftermath's Avatar
    Mar 2008
    Default DGS r8718 9000HD/Cuberevo image
    DGS r8718 9000HD/Cuberevo image.
    This README is for CubeRevo HD model series.
    This document was approved on 24/Dec/2008 by the DGSTATION.
    DGS release r8718: ( 24/Dec/200
    1. Added "post-descrambling with CAM" function on system settings menu
    : When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
    and then you can descramble the recorded file later.
    - The channel in record cannot be watchable.
    - The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
    - even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
    (Caution)
    The recorded file must be performed ˇ?descramblingˇ? before the next smartcard update.
    If descrambling is not running, it is impossible to do the file descrambling anymore
    or able to damage the smartcard since the smartcard has already been updated.
    2. Added HUB function for USB host.
    3. Fixed record programs with DVB subtitle.
    4. Support adjust LipSync using page up/down buttons in Videoplayer
    5. Support NFS function for Linux System in Mount manager
    - changed NFS config in /etc/exports
    ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
    - Removed the firewall of system
    - Removed the firewall of IP table when your system is Fedora
    # iptables -F
    6. Support displays elapsing time on banner of MP3 player
    7. Support Sort function on TMP folder in Recorded files menu
    8. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
    9. Updated language table for Slovak, Bulgarian, Polish and Russian
    10. Fixed DVB EPG bug for HB13 10891
    11. Fixed elapsing time error when schedule recording.
    12. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
    13. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
    14. Added WSS function through SCART
    http://rapidshare.com/files/176402132/DGS_r8718_9000HDCuberevo.rar
  14. #14
    aftermath's Avatar
    Mar 2008
    Default Sifteam v 8717 IPbox9000HD
    SifTeam 0.1.9r8718 ipbox9000 HD
    (Caution)
    # iptables -F
    http://rapidshare.com/files/176426429/Sifteam_8718.rar
  15. #15
    aftermath's Avatar
    Mar 2008
    Default NLB 8728 Image for IPbox900,910,9000
    EDIT :- Please note :- when you install this, go to NLB panel, update from web.
    If your using Incubuscam enable Timeshift, seems like they reversed the problem from other images where you have to disable it. But nice image and stable and fast. Thanks to Dexter.
    CubeRevo nlb8728-910-v1.23
    WEBIF
    login:  	root
    password:	relook
    First time boot with Remote not working, is not fixed yet.. sorry!
    Reboot at lang screen and all is okay.
    Release date : December 26. 2008
    Changes:
      * update: - SVN8728 from DGStation.
      * SVN - Support *.mkv with video player.
      * - If file needs higher class CODEC, file will not be played with video player . In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
      * - Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
      * - Upper card reader.
      * - Fixed some bug for schedule recording.
      * - Fixed record subtitle.
      * - Added "post-descrambling with CAM" function on system settings menu.
      * - Added HUB function for USB host
      * - Support adjust LipSync using page up/down buttons in Videoplayer
      * - Support displays elapsing time on banner of MP3 player.
      * - Support Sort function on TMP folder in Recorded files menu.
      * - Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
      * - Updated language table for Slovak, Bulgarian, Polish and Russian
      * - Fixed DVB EPG bug for HB13 10891
      * - Fixed elapsing time error when schedule recording.
      * - Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
      * - Fixed bugs in scanning and zapping of the channels with diseqc and usals.
      * - Added WSS function through SCART.
      * added - dual recording support with mgcamd, default configs are made for newcs setup.
      * added - nlbpanel 1.38: nlb panel only shows skins available.
      * added - webepg 0.61: Auto import at boot, of epg data when /var/file.xml.imported exists.
      * changes - ushare binary updated to use Kneubi release.
    NLB 8728 MINI
    NLB8728 for IPbox910
    NLB 8728 for IPbox9000
