Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 53
  1. #16
    aftermath's Avatar
    Mar 2008
    Default NLB8728 v1.25
    Thanks once again to Dexter for this Latest NLB image, which has the new Incubus version incubusCam_0.55
    CubeRevo nlb svn8728 v1.25
    for 9000/910/900/250/200
    WEBIF
    login: root
    password: relook
    First time boot with Remote not working, is not fixed yet.. sorry!
    Reboot at lang screen and all is okay.
    Prepared by : Dexter
    Release date : January 5. 2009
    Changes:
    * updated - bootlogo fix.
    * fixed - Internal smartcard reader fix for 910/250
    * added - IncubusCamd 0.55 real update with dual tuner,pip and recording support.
    * added - more information in webif description.
    * added - skin fixes for simple infobar, still a dgs bug here if you jump 2 channels.
    * added - formatting of Harddrive if box fails to do it during bootup..
    * - NOTE: uboot seems to disable some types of HDD during bootup..
    * - ----: When box is ready, remove the hdd and connect again.
    * - ----: and use this format option to init harddrive.
    * fixed - bug in format hdd/usb routine, wrong partition type choosen.
    * removed - reset of cam delay when box goes into panic.
    * added - webif option to change newcs config file between nordic and german setup in webif..
    * added - webif option to change between old and new sci driver (for special card handling)
    * updated - vsftpd.conf , updated with 9MB values for max transfer with ftp..
    * added - panel 1.39: hotfix update from /var now possible. read features_nlb.txt for information on how to instal, if you got no internet
    * added - direct link at top to dgstation original webif.
    (get webif update through panel, to fix missing link in web interface)
    * update - DGS Webif update, for time correction -60 minutes reported in webif using correct GMT.
    * added - Execute startup script before main application, found in /var/etc/init.d , script names start with S .
    * fix - Cuberevo250 VFD messages fix.
    * change - newcs: Default single internal card slot handling for 250/910.
    * change - newcs: Default - newcs is not started on 200/900.
    NLB 8728_1.25 for IPBox9000
    NLB8728_1.25 for Cuberevo 200HD
    NLB 8728_1.25 for Cuberevo 250HD
  2. #17
    V.I.P. Member sotiris70's Avatar
    Nov 2008
    for 910/900/
    Download - CubeRevo mini/Abcom IP900 - nlb8728mini-v1.25
    Download - CubeRevo3000/Abcom IP910 - nlb8728-910-v1.25
  3. #18
    Nov 2008
    CubeRevo nlb svn8833 v1.27
    WEBIF
    login: root
    password: relook
    Release date : January 18. 2009
    Changes:
    * updated - SVN8833 unofficial (BETA) from DGStation.
    * Fix - PANIC situation when DGS Webif is open on pc during bootup.
    * Changed - HDD Format of ext2 formatted usb/harddrive even if it was ok.
    * Updated - multiboot had some issue with usb sticks above 2GB.
    * Updated - multiboot install now works on boxes where usb is mounted as harddrive.
    * Fix - multiboot webif on port 81 was using old webif directory.
    * Changed - ECM info in webif now showing correct info again.
    * Added - newcs 1.63 with updated configs (added 357 mhz to all configs).
    * plugins - Added shoutcast 0.51, bitrate 0.4, favpip 1.9.4, fps 0.1.3
    * skins - deepblue update 3.5 (new livebanner) Thanks to @Crash
    * SVN --- - Recording problem with short HD recordings and 2hr stop fixed.
    * - simple livebanner (OSD option) still causing crash.
    * - DVBSubtitles now pure white with no banner behind.
    * - Signal strength bar is now working again.
    * - Media player got FastForward/rewind on divx support now (not .VOB files).
    * - blind scan - now default/advanced/reset scan.
    * - photoalbum now has background.
    * - Maturity rating now as agerating number in livebanner.
    * - recording with 1tuner boxes, only channels on same transponder shows
    in channel list when 1st recording is active.
    * NOTE----- this is a BETA, and people with external usb harddrive
    can experience recording issues with 2 HD Channel recordings
    (Will be seen as STUDDERING and only a reboot solves it).
  4. #19
    Nov 2008
    CubeRevo-mini nlb svn8833 v1.27 for Ipbox 900 HD
    WEBIF
    login: root
    password: relook
    Changes:
    ** special edition based on 9000/Cuberevo firmware *******
  5. #20
    Nov 2008
    CubeRevo-mini nlb svn8833 v1.27 for Ipbox 910 HD
    WEBIF
    login: root
    password: relook
    Changes:
  6. #21
    Nov 2008
    NLB8873 for IP9000/CubeRevo
    WEBIF
    login: root
    password: relook
    Release date : January 22. 2009
    Changes:
    * updated - SVN8873 official from DGStation.
    * Added - newcs 1.65 with updated configs (added 357 mhz to all configs).
    * Added - nlbpanel 1.41 - now option to install pack.tar.gz from /tmp in panel.
    * plugins - updated bitrate 0.0.5, favpip 0.9.5
    * - DVBSubtitles color fix.
    * - EPG Contents display changes
    * - OSD Teletext - some data not update occassionally.
    * - Fixed local time auto update
    * - updated Polish language table
    * - WebIf updated
    Wolf1976 skin - wolf1976 skin
    - To install Wolf1976 skin
    Ftp to /tmp and use NLBPanel "Install pack.tar.gz from /tmp" to install skin
    you can now choose wolfskin in panel.
  7. #22
    aftermath's Avatar
    Mar 2008
    Default AB_8873 release
    AB 8873 for IPbox9000HD
    AB release r8873: ( 23/Jan/2009)
    1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
       press once FF or REW button, the interval is 10 seconds.
       press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
    2. Add Scan option  on Channel Scan Menu
       When there is no channel list, all these options create with the same result.
       - Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
       - Smart scan : remove current channel list , and scan, and then update FAV list according to  the new channel list.
       - Reset scan:  remove all of the current channels and FAV group, then scan with new channel data.
    3. Add USB upgrade menu
       - Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
         it is useful for software upgrade with USB morory stick.
    4. Fixed EPG contents Display
       - inserted new line on the screen for EPG and extended EPG information as well
    5. Fixed DVB subtitle - color table
    6. Fixed OSD teletext - some old data not updated occassionally
    7. Fixed wrong duration with the file after schedule recording with EPG
    8. Fixed Local time auto update
       - When the last channel time of the Satellite is different from the STB time within 10 minutes,
         the STB time is automatically adjusted with the Satellite time during the STB booting.
    9. Upgrade setting
    10. Updated Web-interface
    11. Fixed small bugs
    12. Support *.mkv with video player.
       - If the file needs higher class CODEC, the file will not be playback with video player .
       -  In case of too higher bitrate file,  it possible to make a problem for playback (especially *.vob and *.mkv.).
    13. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
    14. Fixed some bug for schedule recording.
    15. Fixed record subtitle.
    16. Added "post-descrambling with CAM" function on system settings menu
       : When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
          and then you can descramble the recorded file later.
       - The channel in record cannot be watchable.
       - The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
       - even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
         (Caution)
         The recorded file must be performed ??descrambling?? before the next smartcard update.
         If descrambling is not running, it is impossible to do the file descrambling anymore
         or able to damage the smartcard since the smartcard has already been updated.
    17. Added HUB function for USB host.
    18. Fixed record programs with DVB subtitle.
    19. Support adjust LipSync using page up/down buttons in Videoplayer
    20. Support NFS function for Linux System in Mount manager
       - changed NFS config in /etc/exports
         ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
       - Removed the firewall of system
       - Removed the firewall of IP table when your system is Fedora
         # iptables -F
    21. Support displays elapsing time on banner of MP3 player
    22. Support Sort function on TMP folder in Recorded files menu
    23. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
    24. Updated language table for Slovak, Bulgarian, Polish and Russian
    25. Fixed DVB EPG bug for HB13 10891
    26. Fixed elapsing time error when schedule recording.
    27. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
    28. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
    29. Added WSS function through SCART
    30. RED BUTTON - stretch picture to full screen if 16:9 movie broadcast in 4:3 mode with black in all sides (Without 91HD)
    31. YELLOW BUTTON - direct start of fav PiP plugin (Without 91HD)
    32. Installed plugins - bitrate, Fav PiP, e-mail, weather, Shoutcast, pong, Sudoku, Tetris, HDD temp.
    known issues : sync with audio and subtitle
                   artefact with premiere HD channels from satellite and cable
                   no audio with such as Digifilm channel
                   adjust color table of DVB subtitle for some channels
    AB Official release 8873 for IPbox9000HD
  8. #23
    aftermath's Avatar
    Mar 2008
    Default Cli 8873 image for IPbox9000HD
    Cli Based on Abcom8873 for Revo/9000HD
    Cli R8873
    Based on Abcom 8873
    When you first boot up, LCD gets stuck on start, just hit the exit key on remote control.
    Fixed from Abcom version:
    ---Fixed skins - default crash deepblue final
    ---Fixed plugins
    ---fix libs
    ---Fixed terminfo definitions for TOP command
    Additions from abcom image:
    - DGS/Cli web interface in one
    - Mgcamd/newcs/ and other cams
    - support for incubus/mbox etc on web interface cam control
    - Cron Job support Micrond in /usr/local/bin
    - inadyn in /usr/local/bin > please see /usr/local/etc/inadyn-config
    - some extra plugins
    Abcom Changelog:
    9. Upgrade setting
    (Caution)
    # iptables -F
    Thanks to The usual great plugin coders,, Kneubi, Arvy, Pacco, Timelord, and the rest without support from these guys ip9000 wouldnt be worth sh!t!
    Thanks to NLB team for patched sbox app for epg non-blanking patch
    Hopefully soon we have Cli-panel ready!
    Download Here
    http://rapidshare.com/files/192023828/Cli9000r8873__2_.zip
  9. #24
    aftermath's Avatar
    Mar 2008
    Default DGS Images
    DGS release r9047: ( 5/Mar/2009)
    1. Added additional channel scan options for TV or Radio
    2. Added repeat function in Video Player
    3. Added navigation method for TTXT sub-channel
    4. Display the summary when searching channel
    5. Save the name of recorded file when user want to schedule in EPG
    6. Fixed bug Toptext navigation with TTXT
    7. Fixed bug which was CubeRevo always blocked when first boot After update
    new software
    8. Fixed bug which was CubeRevo-250HD and CubeRevo-mini were not updated
    local timer after AC power off even with Automatic time setting
    9. Fixed Alphacrypt German Language Encoding bug
    10. Included some of the new plugins in CubeRevo SW version.
    - Thanks as below developper for plugin.
    They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
    dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
    pong, sudoku, tetris, andd weather of Neumoteam.
    11. Updated German language translated by Nilse
    12. Removed subtitle language setting in Language Settings Menu
    users control through subtitle option on RCU.
    13. Modified pop up message 'Service is not available' disappears after 5~6
    seconds automatically
    14. Adjusted the position of Pillar box
    15. Adjusted color table of DVB subtitle for some channels
    Note.
    1. Added Multi booting function
    If you want to multi-boot, download usb_config.img in the IPbox stickies :
    Then press number button on RCU which you want booting mode.
    Multi-booting support as below. Official image is number 3.
    1) boot from cdkroot
    2) boot from USB with hdd
    3) original images
    4) boot from release
    5) boot from USB without hdd
    6) boot from SATA hdd
    7) boot from flash
    2. The Digifilm channel works in official CAM.
    artefact with premiere HD channels from satellite and cable.
    RapidShare: Easy Filehosting
  10. #25
    Nov 2008
    Default Sifteam r9047 - 9000 HD
  11. #26
    aftermath's Avatar
    Mar 2008
    Default NLB 9047 for Ipbox9000
    NLB 9047 for IPbox9000
    DGStation/Abcom CubeRevo Series NLB svn9047(binaries) v1.29 :fw3
    WEBIF
    login: root
    password: relook
    FIRST TIME BOOTSCREEN PANIC IS FINALLY FIXED!
    Release date : March 7. 2009
    Changes:
    * updated - SVN9047+ sbox+skin binaries +po files only.
    * plugins - updated favpip 2.1.0
    * plugins - updated hddtemp 0.0.7
    * plugins - all default in /var/plug-in again.
    * emu - mbox 0.4 beta 0023
    * webif - emu and newcs selection made simpler.
    * skins - deepblue and grey updated.
    * emu - EVOCAMD is no longer included in NLB image, no support for it.
    * cardreader- DGS Release had problems with Nagra3 cards. this one works.
    * DGS webif - updated Geckow webif to 1.3.1 (07.03.2009)
  12. #27
    aftermath's Avatar
    Mar 2008
    Default Enigma2 SifTeam Release 0.3.1: USB and Flash
    - fixed the recognition of the DVB-C tuner when is present on the slot number 2
    - fixed a bug on channels scan
    - added flash version for all models
    Flash version here
    USB stick version here
  13. #28
    aftermath's Avatar
    Mar 2008
    Default NLB 9201
    DGStation/Abcom CubeRevo Series nlb svn9207 v1.31
    WEBIF
    login: root
    password: relook
    Release date : April 4. 2009
    Changes:
    * updated - Using DGStation release SVN9207
    * emu - added - Hypercam 1.1
    * emu - added - replace.list config for german provider support
    * webif - new carddriver change between dgstation and custom driver, if issues are found.
    * skins - deepblue, grey and blue updated to r9207.
    Abcom IP9000HD/CubeRevo
    Abcom IP900HD/Cuberevo mini
    Abcom IP910HD/Cuberevo 3000HD
    Abcom IP91HD/Cuberevo 250HD
    Cuberevo 200HD
  14. #29
    Member grizzlyt's Avatar
    Oct 2008
    Default AB Com firmware release-9341
    IPBOX 91-900-910-9000 HD
    AB r9341 30.04.2009
    Change log:
    1. Added automatical services moving when PMT_PID is changed on channel.
    2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
    3. Fixed the bugs that doen't display TTXT on the specific page.
    The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
    4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
    Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2)
    5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below.
    - Press ?1? : Jump to 10% of the recorded file
    - Press ?2? : Jump to 20% of the recorded file
    - Press ?3? : Jump to 30% of the recorded file ????
    - Press ?0? : Jump to beginning of the recorded file
    6. Updated Russian language.
    7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later.
    Files "...r9341DRE.." supported only DRE Cam?s . If you don?t use Dre Cam module, don?t use this image version !!!!
    IPBOX 91 HD
    http://download.abcom.sk/index.php?a...2091HD_Images&
    IPBOX 900 HD
    http://download.abcom.sk/index.php?a...0900HD_Images&
    IPBOX 910 HD
    http://download.abcom.sk/index.php?a...0910HD_Images&
    IPBOX 9000 HD
    http://download.abcom.sk/index.php?a...9000HD_Images&
    Alternative link 9000 HD:
    Free File Hosting Made Simple - MediaFire
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  15. #30
    Oct 2008
    Default Sif Team firmware release-9341
    IPBOX 91-900-910-9000 + DGS 200-2000 HD
    Based on new dgstation release n.9341
    This README is for CubeRevo HD model series.
    This document was approved on 1/May/2009 by the DGSTATION.
    DGS release r9341: ( 1/May/2009)
    1. Update trick speed in File play and live banner
    Advanced : X2, X4, X8, X16 and (X1/16), (X1/, (X1/4), (X1/2)
    2. ADD Proportional jump function in File play
    * Press "1" : Jump to 10% of the recorded file
    * Press "2" : Jump to 20% of the recorded file
    * Press "3" : Jump to 30% of the recorded file
    * Press "0" : Jump to beginning of the recorded file
    3. Updated Russian language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
    4. support NTSC display(you can find u-boot on our homepage)
    5. Update DB
    6. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
    7. Fixed the bugs that doen't display TTXT on the specific page.
    8. Fixed many small bugs
    Note.
    1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
    As you know, even if the Filename Extension is different each other,
    if the video codec is same each other, the two files work like same.
    If the video file's resolution is more than 720 X 576, it will works very well.
    So, we recommend below conditions.
    1) resolution : 720 X 576.
    2) FPS : 24, 25 and 30 fps.
    3) Following video and audio codec.
    Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
    Audio Codec : MP2, MP3, AC3
    When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
    If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
    2. ext3 file system is slower than ext2 normally.
    If you record two HD channels with ext3 at the same time, it may fail in record.
    we have checked the speed as below
    ext2 speed : approximately 7MB/s
    ext3 speed : approximately 3MB/s
    Known issues(on going).
    1. Artefact with Premiere HD channels from satellite or cable.
    Caution.
    1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
    2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
    DGS 200 HD/IPBox 90 HD:
    http://dreambox.sifteam.eu/index.php..._update.tar.gz
    DGS 250 HD/IPBox 91 HD:
    IPBox 900 HD:
    IPBox 910 HD:
    DGS 2000 HD:
    IPBox 9000 HD:
    Dreambox 7025-SS
