And why you think tuned car will get higher top speed than original?
It should reach it faster, but unless you raise rpm limiter and/or vmax limiter and/or change gear relation top speed will be same.
Regards,
Hello!
I wanted to tune my car (A160CDI W169), so a well-known tuner here did a job for me. The problem is there is no difference in performance, the car cannot accelerate over 170 km/h. Can somebody tell me why? There are no fault codes, of course.
ORI file: https://www.dropbox.com/s/1pwqbh0dqe...1037389341.Bin
TUNED file: https://www.dropbox.com/s/c30yda0amj...37389341_tuned
Thanks!
Regards,
Vmax limiter is removed. Car should have 120 hp, or so the tuner said. As I said, also performance is no better.
My other car - Fabia Combi 1.9 TDI 101hp (stock) beats this crappy A160CDI in no time ...
Driver wish = not modified
Geometry control = not modified
Boost limiter = not modified
Boost pressure = not modified
Torque = not modified
Driver whish max = 280 N, +- 50 mg fuel, rail pressure increased after 60mg
Conclusion, car have same power and torque as original.
Good news, you don?t demage engine with mod file.
omglol (22nd September, 2013)
I was told the turbocharger was not touched in any way.
Strange thing is, that the guy who tuned this is a respected Digital Kaos member. I do not understand.
I believe the guy is a respected member here, maybe don?t understend what you whant or maybe send you a file from another job, i supose you try solve the problem with tuner before post the problem here, what?s the answer about ?
I forgot to add, he also made second file after I told him the first one is not good: https://www.dropbox.com/s/t5itcwjlrl...389341_tuned_2
Smayer, could you check this one too? Thanks!
whith second file the only change it?s more fuel after 250 Nm, all modified in %, 9& in torque fuel conversion table and 9% in rail pressure. But fuel it?s almost the same once it?s limites by smoke limiter via boost map.
Sorry but on this file still much work to do just ten maps changed...
