Results 1 to 4 of 4
    V.I.P. Member father ted's Avatar
    Feb 2008
    scotland
    Default HELLLLLLLLLLLLLLLLLLLLLLLLLLLLLP
    ok soft modede wii now when i go to play games i get the title like "supermario galaxy" but when i start game i get this error ..An error has occurred. Press the eject button and remove the disk... etc"
    done a system check can any one help me see the error?
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2006.05.26
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 35995850
    Boot2 v4
    Found 106 titles.
    Found 49 IOS on this console. 4 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/09/22.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Well Ted you posted a sysCheck the last time you had a problem which is exactly the same as this sysCheck so you didn't do what you were asked.
    I've just had to search back to May to find this post. http://www.digital-kaos.co.uk/forums...7/#post1967585
    You haven't installed all 7 wads from d2x v8.0 final wads with MMM.
    Now I'm assuming you trying to play a burnt "supermario galaxy" disc with NeoGamma. As I said before forget NeoGamma and get yourself a mains powered USB hard drive and all games will play.
    I do prefer a Thanks rather than a Like if I've helped you?
    Keith
    2010 Golf GTD (170)
  3. The Following User Says Thank You to Keithuk For This Useful Post:
    father ted (23rd September, 2013)
    Feb 2008
    scotland
    big thanks to keithuk have now installed all the last 7 wads and games play np ,but got another one i may have hit something in the menu while i was playing around and now its not playing original games ???? what have a i done wrong now ???its error 002 white written on a blue background
    Aug 2010
    England
    You may have install all 7 d2x v8.0 wads now but that sysCheck says you hadn't.
    Apart from "supermario galaxy" which I assume is a burnt game you don't say how your playing these games?
    If your using USB Loader GX there is a setting to ignore the #002 error.
    When you tried to play "supermario galaxy" burnt disc was that the same error number?
    When I tried NeoGamma along time ago that showed a 1167 error number DVD read error which I didn't find a useful solution so I use the 3 USB Loaders and they don't fail to work.
    How to Officially fix #002 Error from burned Wii/Gamecube Games
    There are a few video's on YouTube if you search neogamma error number 002.
    Keith
    2010 Golf GTD (170)
  6. The Following User Says Thank You to Keithuk For This Useful Post:
    father ted (24th September, 2013)
