Results 1 to 13 of 13
Thread: the box super
    Member jackd's Avatar
    Feb 2009
    Default the box super
    i have flashed the new software onto the box but now it will not pick up any chanels when i do a scan.
    some times it will pick up the chanels but it will only work 4 about 5 to 10 minits and then it will say scrambled or bad signal. i have done a factory reset and set default key nad turned key emu on
    can any one tell me what is wrong with my box THANKS
    Top Poster bumble's Avatar
    Jan 2009
    hi,,
    which firmware have you used??
    v 1.09 is for ireland,,
    thats if your box is super box usb,,
    or is your box a starview 3 ?
    bumble
    DK Veteran bigfella's Avatar
    mick's arse in america
    check all ur leads...check u have the correct firmware for ur box ...check if u selected the correct cable provider...see if flash is successfull by goin to menu goin tosystem set up goto system set up n it shud tell u which firm ware is on ur box
    stockport
    assume its sv3, cos you say emu, not keycode. firmware is 8.02 or 8.04. should be fine then unless you're in the emerald isle...ynwa
    Feb 2009
    ive got 8.04 installed it works when it wants to
    Feb 2009
    can anyone tell me what is wrong with my box
    or do i need to buy a new one
    Nov 2008
    Default Box Super 3 sound
    Have had ntl hitting box can get channels for a while no Audio and then they boot it again. Have to wait for the brainy ones to work out some new codes.
    May 2009
    Default star view 3
    hi people im deco. im new here. could any 1 please tell me is there any new firmware for my box???. im missing the sports big .im in dublin. or is it all over for my poor box??? i heard kryptvview is doing a box that still works??? is this true and anyone know how long
    it will last?? help me plz ...ps its a starview 3
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    not too long im afraid they have set june as date for all change , i wouldn't go buying anything for a while , so i have been informed.
    satsmo's Avatar
    Jun 2008
    Who set that date?
    satsmo's Avatar
    Jun 2008
    Quote Originally Posted by deco30lfc View Post
    Yes the Kryptview is working at present with the channels gone to Nagra 2. Nagra 3 migration is something know one can be sure of.
    The 1802 stream is present but they presently simulcrypt on 1800 and 1801, (Nagra 1 and 2).
    satsmo's Avatar
    Jun 2008
    Quote Originally Posted by jackd View Post
    Have you tried a reflash? Also check all your connections as it may be your cabling and not your box.
  13. #13
    Feb 2009
    i have checked all cables and re flashed the latest software but it still wont work do you think i need a new box
