looking at your bosch number.....im sure alot of tools...can do this!
look around the forum , im sure you will find an immo killer or ecuvonics tool to do it....
is there any solution to turn off immo in this ecu? should i install emulator? someone told me that if i remove immo in this ecu without emu gas pedal will not work...??? please help me with it. i have searched the form but found only some italian slution but i dont understan a word . i need good discription of this solution.
Attachment 220968
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
lonczyn (27th September, 2013)
Hello friend
Write these to new 24c04 lift pin 7 from eprom and join to pin 8.
I hope you understand.
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
ABD ERRAHMANE (25th December, 2018), aissa1312 (22nd October, 2019), Bacha mini (31st December, 2020), lonczyn (27th September, 2013)
thx a lot for you assistance. unfortunately immo killer and other software cant do this right. connecting pins of the memory doesnt work. car start but when you are trying to push gas pedal it stops to work as my frient told me. i have just installed emulator made by him and its working good. he told me that he was trying to to on many ways but no effect. thx a lot guys for your support.
i made it fiew times worked good
Change 24c04 by ST24C04 protected against writing welding pine 7 on 8 without 7 affect(touch) the pcb
laguna 1.9dti 0281001766 immo offis there any solution to turn off immo in this ecu? should i install emulator? someone told me that if i remove immo in this ecu without emu gas pedal will not work...??? please help me with it. i have searched the form but found only some italian slution but i dont understan a word . i need good discription of this solution.
I WANT PASSEWORD FOR WINRAR
Can you send me the pass?
Thanks,
pls PASSEWORD FOR WINRAR
pass please
PASS PLEAS
MOT DE PASSE s'il te plait :amoureux:
