Results 1 to 7 of 7
    Jan 2009
    Default Need advice about auto oscilloscope
    I doubt about ordering Hantek DSO3064 4CH Automobile Diagnostic Oscilloscope or USB Autoscope-1
    InjectorService.com.ua?•?USB Autoscope
    Hantek DSO3064 with full adapter cables and clamps is about 420-650usd,
    Autoscope-1 is ~700usd but there is DIS ignition systems kit + pressure transducers
    Hantek DSO3064 looks nice, BUT, I have hantek 1008c and sw is very bad, crashes no good measure,no good save and ****ize pattern later etc....and when I see dso3064 use almost same sw
    Autoscope-1 use sw that is much better, similar as TEXVIK
    So need advice from owner of DSO3064 or Autoscope-1
    Tnx
    Aug 2011
    Spalding
    Just bought a picosope myself.
    Cant recommend high enough, great piece of kit.
    Nearly bought the DSO but in the end went for the pico because of the support available.
    Martin
    I had a cheap DSO. It was Ok until it got damaged. Out of warranty.
    Next I bought a Picoscope. Software is 20 x better.
    And Picoscope has a good reputation of non failure.
    I have it for 2 years. Until now, it?s perfect.
    Aug 2013
    hi, - I have been using more than two years Autoscope-1. - is worth the money. - This is exactly the oscilloscope dedicated to the car. - Our set to be additionally purchased Spark Gap.
    Jan 2009
    I know about pico sw, but autoscope1 also is good sw, so will get autoscope 1 even not possible to catch diesel injector (autoscope 3 can)
    Tnx
    Jan 2009
    Sorry, double post
    Member tirrofa's Avatar
    I've used a few oscilloscopes, for the last 7 years Pico 3000 and Pico 4000 Automotive kit, both 4 chanel you will not get better than these.
    The support from Pico is second to none..
    If I've helped please say Thanks
