Results 1 to 10 of 10
    romania
    Default sagem s3000 megan2
    i need full flash for RENAUL MEGAN 2 ecu SAGEM S3000 1,4 16 V i want too write with piasini !
    thanks !
    hi
    report pls
  3. The Following 2 Users Say Thank You to tivito For This Useful Post:
    car_soft_gorj (27th September, 2013), lazqzer (21st September, 2020)
    romania
    read ok with piasini flash mache 2 bridge conexion
    Execute crc ... ok
    ****yzing ECU ........
    No ECU found, please check wiring. please help
    romania
    any ideas ?????
    araby80's Avatar
    Jun 2013
    INSIDE ECU
    i have the same problem
    araby80's Avatar
    Jun 2013
    INSIDE ECU
    put 470 ohm resistor
    biktel's Avatar
    Jun 2009
    Romania
    not working with 470ohm resistor. any ideea?
    Nov 2012
    smartville in front of a OBDplug
    work with genuine piasini tool
  10. #9
    Apr 2014
    Spain
    Hi. MMC Flasher 2 with Renault module activated work by OBD or onboard conected ECU.
    Easy ang comode.
    Regards.
  11. #10
    Jun 2017
    Default maxima potecia por favor megane 2 1.6 16v 111cv
    alguien me ayuda con la maxima potecia para este megane 2
