Results 1 to 4 of 4
Thread: CTEK MXS5.0
    Top Poster + 666_devil's Avatar
    Hesperange
    Default CTEK MXS5.0
    Good enough to charge the car while flashing?
    Dec 2010
    No. This is too weak!
    Hesperange
    Too late I bought that one
    Dec 2010
    Hello
    Many modern cars pull 20 amps or more on ignition on. A Q7 V8 tdi edc16 sucked 27 when i tested it. And then you need to cover the voltage drop when the fan starts to run. A ctek 25.000 with designated "supply" switch is the minimum you should use. A 5.0 is good for a bike or an old polo only.
    greetings,
    filecloud
