Results 1 to 4 of 4
    Sep 2013
    Default how do i install aubouquets on my dreambox 800hd clone
    how do I install aubouquets on to my dreambox 800hd clone running dreameleate blackhole.from start to finish thanks
    Member gaelicred's Avatar
    Feb 2013
    Dublin
    If you have tspanel go into that ( if not get it ! ) select addons / linuxsat_support_Addons / {plugins} , top of the list is autobouquets E2 28.2E (presume your 28.2E !?) Install it , when you restart select the autoboquets plugin , when the window pops up press the info button on your remote there is a guide that should help you then press menu on your remote to configure the plugin , its easy enough to do !!
    Sep 2013
    Quote Originally Posted by gaelicred View Post
    can not find linuxsat_support_Alinuxsat found addons but nothing but is that the same as tspanel if not how do I get that sorry new to this.
    digicon's Avatar
    Jul 2009
    Get the .ipk from this forum FTP to your temp folder and install that way via the menu of your image or via telnet
