Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Default PKT_0.75_9000_usb.tar.gz
    How can I boot from USB stick with PKT_0.75_9000_usb.tar.gz?
  2. #17
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by hernest30 View Post
    have you unpacked the image to the USB stick ?
    also what image you got in Flash ?
    normally you need to flash a mutiboot file over the top of your flash image using PCeditor the same was as you flash a normal image.
    once all that is done , you simply turn the box off, then hold in the number 2 button on remote control , switch the box on and keep the number 2 button in for 5 seconds. then let go.
    it should then boot to E2 image on USB stick, if at first it gets stuck on botting, switch off the box and back, try a few times.
    Be carefull there is lots of corrupt E2 images out there on the net.
    here is a working E2 PKT 0.75 one 9000_usb.tar.gz
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
  3. #18
    liverpool
    flash tools version1.0.2 or over had same prob sorted
  4. #19
    I followed the instructions but can't boot from usb. When exactly do i have to press the button "2" for booting from usb?
  5. #20
    thank you for the update, really helpful
  6. #21
    Feb 2011
    usb boot edimiyorum
  7. #22
    Jul 2011
    For some reason I cannot boot from USB anymore (it did work!), it appear that my console env setup is gone. Hopefully I'll be able to fix it downloading the file attached to the first post. SatRider
  8. #23
    Jan 2012
    works
    nice guide thanks
  9. #24
    Mar 2012
    thank youuuuuuuuuuu
  10. #25
    Mar 2013
    Thanks! it works.
