Results 1 to 10 of 10
    BALI7605's Avatar
    Brisbane QLD
    Default Holden Chevrolet Commodore Alloyetch Reprogramming Bosch ECU
    Hello All,
    I have a customer who wants to kill me at the moment, it is a Holden Commodore V6 3.6 it has a bosch ecu
    which i need to replace and i have a replacment unit but that is from a 175kw engine and the customer has a 190kw one.
    The good thing i have a friend who has a 190kw car i can read the data from it and program it to the customers new ecu BUT neither kwp2000 galletto or MPPS would read the thing.
    Is there anyone who has a dll for kwp 2000 or any other ideas??
    By the way is this a bosch me9.xx? or 7.1.x????
    here is a photo of the unit
    thank you
    Bulgaria
    Seems to be ME7
    You can try with MPPS, but hw version should be the same!
    BALI7605's Avatar
    Brisbane QLD
    HW version is the same if i had access to Holden TIS i could reprogram it but i dont
    Bulgaria
    You can use TIS with any passthru interface.
    BALI7605's Avatar
    Brisbane QLD
    I have an MDI BUT i can not get hold of a Holden TIS,
    I have all the TIS version of the world but the aussie.
    Do you know any J2534 software which can read and reprog and not model specific??
    Thx
    Bulgaria
    No. Sorry.
    Just ask someone in your are,most guys can do this work now.
    its Me 7.6.x Fgtech 2 can read it on bench and sometimes oBd in boot mode!
    Also immo is in flash so swapping the info may not work! swap map values only!
    https://www.acdelcotds.com/acdelco/action/subscribehome
    Just pay $55 for days access to Tis2Web and get the correct File. Bear in mind not all the alloytec 175 190 ecu are compatible, They also have a high failure rate during flashing. Otherwise send it to a professional shop and get it reflashed.
    BALI7605's Avatar
    Brisbane QLD
    Thank you guys the info great help.
    i can work it out from here
